Author Topic: variac transformer question  (Read 2822 times)
Offline radiogeek97Topic starter
« on: March 22, 2013, 05:05:55 am »
i was wondering could a variac transformer function function as an effective isolation transformer.  i wanted to mains isolate some devices before i test them with my scope i dont have an isolation transformer bout have access to a variac.
thanks
john
Offline Psi
Re: variac transformer question
« Reply #1 on: March 22, 2013, 05:09:22 am »
no, variacs provide no isolation.
Here's a diagram of the wiring
As you can see, the input and output are connected.
« Last Edit: March 22, 2013, 05:14:37 am by Psi »
Offline digsys
    • DIGSYS
« Reply #2 on: March 22, 2013, 05:10:07 am »
Absolutely NOT !! A Variac has one side Referenced t the output ie it's an auto-transformer.
Sorry, you'll need an isolation transformer.
Offline grenert
« Reply #3 on: March 22, 2013, 05:17:52 am »
There are a very few variacs which have isolation, but nearly all variacs DO NOT have isolation.  So, most likely your variac will not be isolated.
One model which has both variable AC and isolation is the BK Precision 1653A:
http://www.bkprecision.com/products/power-supplies/1653A-150v-2a-ac-power-supply.html
Another is the Global Specialties 1505:
http://www.alliedelec.com/search/productdetail.aspx?sku=70156612
« Reply #4 on: March 22, 2013, 10:33:49 am »
thanks fellas i appreciate the help.  i am sure the variac my neighbor has is not the one of the very few that provides isolation.  I guess i will check ebay for a resonable isolation  xformer.
thank you all !
