Author Topic: Very simple OP-Amp Tester  (Read 2557 times)
Online Martin72Topic starter
  • Testfield Technician
« on: October 09, 2022, 04:55:04 pm »
Here´s my very, very, very simple op-amp tester, based on an elector projekt.
Circuit is the same, I´ve designed the layout different and corrected an issue with the supply-polarity of the quad-amp socket (plus twisted with minus).
It can be used on single-, dual- and quad op-amps types with the same pinout (TL071, 072, 074, NE5532, 34 and so on).
A biploar squarewave of about 1Hz will be generated and feed the DUT sockets.
They are in such manner connected that the test op-amp will work as a buffer.
Very simple...But it works.
Of course it´s for rudimentary Go/No Go Tests, nothing else.
But better as nothing to have.. 8)
Short video with a TL074 inserted:
https://youtu.be/Rq2O61mSrSk
Martin
« Last Edit: October 09, 2022, 04:56:46 pm by Martin72 »
The following users thanked this post: egonotto, 2N3055, tubularnut
Re: Very simple OP-Amp Tester
« Reply #1 on: October 09, 2022, 09:05:57 pm »
CAM output for the tester, just load this zip file up to for example JLCPCB to get the pcb build.
All my self designed pcbs in the last 3yrs I´ve bought from them, good quality for an insane price, with one exception.
You must take care what placement of the...the...argh, didn´t know the right explanation in english...
What the name positions of the elements on the pcb concerns, e.g. R4, R2 and so on..
If you leave it as it is, names could be covered by the body drawings.
But this is the only con, the rest is high quality.
The CAM output also contains the BOM.
Martin
Offline Messtechniker
« Reply #2 on: October 09, 2022, 09:29:03 pm »
My circuit here
https://www.wellenkino.de/557/viewtopic.php?f=7&t=358
goes a bit beyond opamp testing since it was developed for selecting opamps for offset. Might be of interest to you.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: egonotto, Martin72
« Reply #3 on: October 09, 2022, 09:40:55 pm »
Wow, not bad.  :-+
Could be interesting when you can´t control the offset directly.
(Or you don´t want to offset the amp by using resistors from Ub to his inputs)
Next thing planned was a circuit similar to the tester but for comparators explicit.
I think I took a triangle signal for it.
And then taking both together.
« Last Edit: October 09, 2022, 09:43:53 pm by Martin72 »
Online ledtester
« Reply #4 on: October 09, 2022, 11:53:54 pm »
One test I've used to distinguish real TL082's from fake ones is to put it the oscillator circuit in this post:
https://www.eevblog.com/forum/beginners/op-amp-square-waves/msg922779/#msg922779
This is basically a test of the op-amp's slew rate -- the higher the slewrate the higher frequency it can generate. Perhaps that would be another good test to have in an op-amp tester.
« Reply #5 on: October 10, 2022, 09:05:08 pm »
Yes and no joke, that was the first testcircuit I´ve realized on a breadboard..And wondered how dramatical the difference between a TL072 and LT1013 was, in case of bandwith.
To test both amplifiers on a dual-OP amp I´ve used the well known circuit for a squarewave-triangle gen.
But a scope is needed and I want to have a stand alone version.
But why not combine all circuits on one board....Hmm...A lovely idea.
To be continued.  8)
