Author Topic: VICI VC8145 New software for Linux ( and Windows coming soon )  (Read 1651 times)
Offline Inflex
    • Charters Towers Phone & Computer Repairs
« on: December 24, 2018, 03:42:16 am »
For people wanting a simple interface on linux for the VICI VC8145,  have written up
   https://github.com/inflex/VC8145
Linux version uses SDL2 for the GUI, it also offers data logging.  Easy to drop it to CLI only as well with some code removal.
Windows version will come up later, requires a bit of a change in the GUI & serial code of course but the decoding of the protocol/data is done.
NOTE - If you buy one of these meters and hook it up via USB, unless you have a good USB->serial cable which provides power to the serial port, you will encounter loss of data from the port and a lot of bad data frames.  Either go true serial port, or get a very good cable (even the genuine FTDI cables don't always provide enough power ).
Two videos on the process of writing it up;
Part 1 -
Part 2 -
« Last Edit: December 24, 2018, 03:45:50 am by Inflex »
Magicsmoke abuser | What I repair daily on YouTube | FlexBV
- BoardView
| Paul Daniels
The following users thanked this post: nctnico
Offline STC16
Re: VICI VC8145 New software for Linux ( and Windows coming soon )
« Reply #1 on: February 11, 2019, 04:05:37 pm »
I stripped the opto couplers and associated components from the RS232 section in my VC8145, and fitted an HC05 bluetooth module.  Very easy to do, utilizing the existing 5 pin connector, and it works brilliantly.
Currently writing a Mac app to interface with it, using the protocol data floating around on the web.
Steve
Offline DickGrier
« Reply #2 on: January 11, 2020, 04:59:29 am »
I have written a Windows 10 application that can be download from my homepage.  It is not based on other work, so you may notice some "things."  See: http://hardandsoftware.net/Downloads.htmhttp://hardandsoftware.net/Downloads.htm  It is free, of course.
Offline Microcheap
« Reply #3 on: January 11, 2020, 05:16:44 pm »
Thanks for the tip, I will try it later with my meter.
Meanwhile, I have been using another opensource alternative called VC8145 Control, it works without a problem with Win10 as well: https://www.26th.net/public/projects/vc8145/
Offline Inflex
« Reply #4 on: May 09, 2020, 12:51:31 pm »
That's vastly more comprehensive indeed!   Agreeably, I write these small versions strictly so I can use them with OBS for youTube streaming and keeping CPU load down :)
- BoardView
| Paul Daniels
Offline HKJ
    • Tests
« Reply #5 on: May 09, 2020, 01:11:03 pm »
You can also use this program for the VC8145:
https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
I believe it works on Windows, Linux and Mac
Offline Inflex
« Reply #6 on: May 09, 2020, 01:27:39 pm »
Another exceptionally complete suite.  Definitely if I'm going to be doing logging / multi-device setups like that it'll be the sort of software I'll grab too.
- BoardView
| Paul Daniels
Offline HKJ
    • Tests
« Reply #7 on: May 09, 2020, 06:57:19 pm »
Even with one device connected it can do a lot more stuff than standard multimeter software.
The only thing missing is analog display and a limits alarm, do anybody ever use these functions? The missing limits alarm may in some cases be replaced by scripts, the software can easily turn a power supply or load off when the voltage or current passes a specified limit.
