Author Topic: Victor 98a+ calibration  (Read 417 times)
Offline Dezmond2Topic starter
  • Country: ua
« on: November 14, 2024, 03:26:03 pm »
How to calibrate Victor 98a+ ???  :-DMM
Offline valcher
  • Country: ru
Re: Victor 98a+ calibration
« Reply #1 on: November 14, 2024, 06:23:09 pm »
Hello!
I have a Victor 79A+ multimeter-calibrator, but I don't know if it will help you, the devices are different.
To enter the calibration mode, you need to press the REL and RIGHT buttons on the switched-off device and turn the switch to the parameter where you need to calibrate. Range selection - RANGE, scale start/end - REL, data saving - Hz. Each calibrated range is saved separately.
Voltmeter calibration example:
Range 0...5 volts.
Close the inputs - 0 volts.
Press - REL / go to the beginning-end of the scale /
Apply 5 volts to the input.
Press - Hz / save calibration /
Press - RANGE / select the next range /
и.т.д
Play around with the keys, your device may have other entry points into calibration. But be careful, mine has a three-key combination to reset the entire calibration, I got caught.
Удачи!
« Last Edit: November 14, 2024, 08:21:20 pm by valcher »
The following users thanked this post: Dezmond2
  • Country: ua
« Reply #2 on: November 14, 2024, 08:05:04 pm »
And what happen after "turn the switch to the parameter where you need to calibrate"? DMM turn on?
98A+ not have LEFT button. On pic you mark RIGHT button? )
Offline valcher
  • Country: ru
« Reply #3 on: November 14, 2024, 08:20:06 pm »
That's right, the right one, I did something wrong.  :o
While holding the keys, move the switch to measurement and the device switches to calibration mode.
  • Country: ua
« Reply #4 on: November 14, 2024, 10:23:05 pm »
Hold + Range + Power = Calibrating Mode
  • Country: ua
« Reply #5 on: November 15, 2024, 02:34:55 am »
I have chines guide for calibrating...
Offline valcher
  • Country: ru
« Reply #6 on: November 15, 2024, 03:32:14 pm »
Great, the calibration method is the same.
Offline Fungus
« Reply #7 on: November 15, 2024, 08:02:32 pm »
You can put it through google translate:
https://translate.google.com/?sl=auto&tl=en&op=docs
