Author Topic: straight  (Read 11248 times)
Offline GEuser
  • Is Leaving
straight
« on: August 19, 2014, 02:38:18 am »
Q
« Last Edit: August 30, 2016, 12:18:39 pm by GEuser »
Soon
Offline radhaz
Re: Victor VC3165 counter straight outta the box .
« Reply #1 on: August 19, 2014, 02:54:04 am »
What an age we live in, when a hobbyist can acquire such test equipment.  :-+
Online nctnico
« Reply #2 on: August 19, 2014, 04:21:56 pm »
Interesting!
What would be a nice test is to sweep the frequency to see how flat (or not) the sensitivity is.
Online nctnico
« Reply #3 on: August 20, 2014, 10:12:21 am »
I was more interested in what the sensitivity is at 2.4GHz (the maximum frequency).
The following users thanked this post: sab
Online nctnico
« Reply #4 on: August 20, 2014, 01:01:50 pm »
I couldn't resist  :scared:  I bought one  :palm:
Online nctnico
« Reply #5 on: August 27, 2014, 01:04:24 pm »
I just received mine and did some tests on the sensitivity (voltages in RMS) according to my RF generator:
100MHz  70mV (-10dBm)
2GHz     70mV (-10dBm)
2.5GHz  130mV (-4.7dBm)
Over 2.5GHz the sensitivity falls off sharply. There is also between 1 and 2dB loss in the cable I used at 2.5GHz so the sensitivity at high frequencies is actually slightly better than shown above.
Offline Teledog
« Reply #6 on: March 10, 2015, 05:16:43 am »
Got one myself..after a fair warm up found it drifted.
Replaced the (crappy) thermal Xtal setup with an OCXO..
..and calibrated THAT with a GPSDO ('cause I'm anal?!)  :-+
Emailed the mfr. for a schematic & they were very good about emailing the osc. section back to me
Offline Marc_Und
« Reply #7 on: May 07, 2015, 07:25:30 pm »
Any chance you can supply some photos, and instructions on how you did that, as I interested in attempting a similar modification on my VC3165.
Or on how to adjust its calibration....
 I have just got myself a 10 MHz Rubidium Freq Standard unit (FE-5680A), and it is showing that my Freq. Counter's calibration is out slightly (i.e. it is reading 10.000020 MHz, instead of 10.000000 MHz), and I would like to improve it.
 :-// :-/O :-//
Thanks.
Offline pascal_sweden
  • Country: no
« Reply #8 on: May 08, 2015, 12:11:53 am »
What are the 2 big units underneath the Victor? This seems very expensive equipment!
So you have these 2 professional units, and still you need a Victor?
Did you loan them, or was the photo taken at your company? =)
Is it possible that this Victor VC3165 is also rebranded under Velleman DVM13MFC2?
http://www.velleman.eu/products/view/?country=es&lang=en&id=366114
There are even some unbranded ones on Ebay, so you can give it your own name :)
http://www.benl.ebay.be/itm/VC3165-Radio-Frequency-Counter-RF-Meter-0-01Hz-2-4GHz-Victor-Professional-Tester-/181336910881?hash=item2a3885ac21
I read that it performs very well on high frequencies, but not so good on low frequencies.
Did you also make the same findings during your tests?
« Last Edit: May 08, 2015, 08:59:27 am by pascal_sweden »
  • Country: no
« Reply #9 on: May 08, 2015, 07:42:25 am »
Which company is the original manufacturer? Is it really Victor? Because these units are OEM.
Maybe you can suggest your design improvement to them, and together make a better frequency meter. They could give you some "Victor" company shares in turn :)
Online nctnico
« Reply #10 on: May 10, 2015, 03:43:05 pm »
Please share how to do this modification!
Offline Marc_Und
« Reply #11 on: May 17, 2015, 11:13:33 pm »
Does anyone know what the missing components on the left hand-side of the main board, were meant to do?
Would we get extra functions/channels if we fitted the missing components??
Offline Electro Fan
Offline MisterBiscuit
« Reply #13 on: July 18, 2015, 05:33:51 pm »
 :-// :-/O :-//
Thanks.
+1
@Teledog, can you post the information that you have? I'm interested in the details around the oscillator circuit to wire in a more accurate oscillator.
Offline Datman
Re: straight
« Reply #14 on: April 28, 2017, 08:43:27 am »
