Author Topic: Video Repair of an Agilent E3620A Plus IC Decapping Tutorial  (Read 6245 times)
Offline Hugoneus
    • The Signal Path Video Blog
« on: April 26, 2015, 05:23:00 pm »
Enjoy!
Watch the video here: [41 Minutes]
http://youtu.be/HembEL6PbE4
More videos at The Signal Path:
http://www.TheSignalPath.com
Offline radhaz
Re: Video Repair of an Agilent E3620A Plus IC Decapping Tutorial
« Reply #1 on: April 26, 2015, 07:11:07 pm »
Great video!
Offline Vgkid
« Reply #2 on: April 26, 2015, 07:19:49 pm »
Thanks for the video, the joys of chemistry. At least nothing blew up.
Offline HighVoltage
« Reply #3 on: April 26, 2015, 09:20:07 pm »
Another great repair video from you.
Thanks so much
Offline Hugoneus
« Reply #4 on: April 26, 2015, 10:30:43 pm »
You are welcome! :)
Offline dadler
« Reply #5 on: April 26, 2015, 11:48:31 pm »
Only on your channel do we find the unique combination of:
  • the cleanest and most organized home electronics lab I have ever seen
  • nitric acid
  • a michelson interferometer
  • the insides of scopes that cost as much as a house
  • frequent use of the word 'terahertz'
  • at least two of every class of test equipment one could dream of
  • attempted repairs that almost always turn into successful repairs
  • frequent use of various alcohols for both cleaning and imbibing
  • a guy who just happens to work in the building where the transistor was invented
Needless to say, love the channel! Thanks for another great video--very cool to see the magnified dies that you were able to reveal at home with careful chemistry.
Offline MadTux
« Reply #6 on: April 27, 2015, 01:47:55 am »
Great video, nice to see that the HP E3620E works again.
That decapping method you use is inefficient, however.
If you go fully destructive, ie fully dissolved package, you better use hot/boiling sulphuric acid in a test tube, since it's much easier to get and has no nasty NOx production. Furthermore aqueous nitric acid is far more corrosive to metals => much more damage to the metal layers of the die.
The trick with nitric acid is that you can remove the package specifically, with no attack to metal traces, since pure nitric acid has no water in it that removes the oxides/nitrates which protect the metal. To get the anhydrous nitric acid, you need an glass destilation setup, where you can remove the water from commercial 53-65% nitric by using 98% sulphuric acid as dehydration agent or use sulphuric acid to liberate pure nitric acid from alkali metal nitrates (NaNO3, KNO3).
 Works really great, did that several years ago and as I was quite pyromanic back then, I had plenty of anhydrous nitric acid available 8). Best method to decap the chip is to put it onto hotplate (into fumehood/outside, with gloves and faceshield, since it splashes quite strongly), heat in near/to the boiling point of nitric acid and use a pipette to put single drops of nitric acid onto the center of the chip, where the die sits.
The nitric acid will vigorously attack the package and start to boil. This removes any reaction products that might attack the bonding wires or lead traces in the package. When finished, clean with ethanol and put in ultrasonic bath with acetone for a while.
If you stop at the right time, you can get quite nice chips with bond wires fully intact, that even work that way. Difficult part is to know when to stop, since black goo from the package obscures the die in the process and you have to guess when to stop. Too long and the die gets fully exposed and detaches from the package.
« Last Edit: April 27, 2015, 02:00:36 am by MadTux »
Offline Hugoneus
« Reply #7 on: April 27, 2015, 01:54:57 am »
Thanks for your suggestions. By the way, the die is not in danger from the acid. Only the pads have exposed metal and are often made from Al.
Offline MadTux
« Reply #8 on: April 27, 2015, 02:25:08 am »
I know, there's a SiO2 passivation layer on top of the die.
But in my experience it doesn't completely stop the acid from attacking the chip, especially on small feature sizes and if you don't know how long to wait until the chip is completely dissolved. So I expected far more damage by using aqueous nitric acid, than actually happened (hadn't watched the complete video when posting)
« Last Edit: April 27, 2015, 02:28:25 am by MadTux »
Offline Hugoneus
« Reply #9 on: April 27, 2015, 01:56:25 pm »
@dadler
I should have somehow used liquid nitrogen too!
Offline ion
« Reply #10 on: April 27, 2015, 05:48:47 pm »
Another great video!
What temperature did you heat the nitric acid to?  I had a go at decapping a while back but the cold acid didn't do anything.  I was planning on trying it on a hotplate and it would be nice to have a starting point.
Offline BFX
  • Country: sk
« Reply #11 on: April 27, 2015, 06:49:46 pm »
Finally video when you need to use longer time than one hour your soldering iron ;)
But first part of video is ... so lucky man :) (standard)
But at all, youur videos is the best one :D  :-+
« Last Edit: April 27, 2015, 06:54:41 pm by BFX »
Offline mtdoc
« Reply #12 on: April 27, 2015, 07:01:28 pm »
@dadler
Great video!
How hard is it to get nitric acid outside of a professional setting?  I haven't had access to any since my basic science research days. Obviously dangerous stuff if proper precautions are not taken.
I do have easy access to lots of liquid nitrogen. What kind of use is it for an electronic hobbyist?
Offline macboy
« Reply #13 on: April 28, 2015, 02:17:09 pm »
Enjoy!
I enjoyed watching your repair of the water damaged E3620A. I have a few of those supplies myself and I really like them. They are low noise and stable.
They are hard to find, but you can eventually locate two service notes for the E3620A on Keysight's website. One of them covers the issue of broken grey key caps. If your supply falls within a specified serial number range, they will replace them free of charge. The service note says "Agilent responsible: Always" meaning there is no expiry on their liability for replacing those broken key caps. They sent me several sets for my supplies a few years ago.
List of service notes for E3620A
Service note E3620A-07 concerning cracked grey key caps
