Author Topic: Vintage Teardown: RFT G-1004.501 (DMM)  (Read 464 times)
Offline kblueTopic starter
« on: September 03, 2024, 11:06:54 pm »
Part Nr. 1 - The outsides!
Greetings!
Mayhaps stuff like this is kinda interesting for some folks. Its a simple one but i do like this old stuff and tech :D
This particular unit was sold on: 25. October 1990
3 1/2 Counts
DC V ranges: 200 mV, 2 V, 20 V, 200 V (0,25% +2) // 1000 V (0,5% + 2)
DC A ranges: 200 mA, 2 mA, 20 mA, 200 mA, 1000 mA (0,5% +2) // 10 A (1% +2)
AC V ranges: same as DC (1% +4 for all ranges)
AC A ranges: same as DC (1,25% + 4 for all ranges)
Ohms: 200, 2k, 20k, 200k, 2000k, 20M (0,5% +3)
Diodetest: 0,1 mA / 0 - 1,999 V (max. out: 3,4 V) + Continuity
Batterylife: >1500 h
This meter seems to be working just fine, except for the black zones within the LCD. So far it seems to be within spec! So nothing to repair i guess :D For the first post, i'll show some pictures from the outside, the battery compartment and the schematics. There will be more from the inside later this week.
2360363-0
With the original box, documents in rus + ger language, schematics and a warranty card its quite a good catch!
2360367-1
The display (9mm in heigh) has its problems. But its usable! I could remove the polarization filter :P But as some of you know, it wouldn't be usable from that point forward.
2360371-2
The original schematics. In this case the RUS variant. The other one would be in german.
2360375-3
The bottom side with some markings like "RFT veb mikroelektronik >karl marx< erfurt" (RFT = Rundfunk- und Fernmelde-Technik / veb = Volkseigener Betrieb [publicly owned enterprise) and yes, this meter needs 6 batteries! And no, your eyes don't deceive you ... i use miserable Vartas. I had these on hand. I'm sorry! Please put the stones back to the ground where they belong and don't use them as a throwing weapon! :D
The following users thanked this post: coromonadalix, ch_scr
Re: Vintage Teardown: RFT G-1004.501 (DMM)
« Reply #1 on: September 07, 2024, 07:19:46 am »
Part Nr. 2 - The inside!
But wait, there is more!
2363851-0
Ye, switches are big and they take a lot of space.
2363855-1
2363863-2
Big solderjoints for the 10 A Shunt. Guess something like that wouldnt pass safety ratings today?
2363859-3
1kV Input Section with a big resistor. Speaking of Resistors ...
2363867-4
2363871-5
This meter is packed with resistor-networks. Some might be even precision work (-: What else do we need in such a nice meter? Mhmm.
2363875-6
Chunky diodes of course! Who does not want some chunky diodes in his / her meter? It seems these diodes or rather the legs are cursed with tin whiskers?
2363879-7
One of two main attractions! The Chip C7136D, which seems to be a copy of the ICL7136 (Data Sheet from analog.com).
2363883-8
The second main attraction! Our 1,235 V Vref B589Nm (50 ppm/C°) which is a copy of the AD589. No surprise at all, eh? So far the meter seems stable and accurate for its 2000 Counts. The display is a bummer, mayhaps i'll source another unit with missing parts or something for a display-swap.
Best wishes!
The following users thanked this post: Vgkid, coromonadalix, ch_scr
Offline coromonadalix
« Reply #2 on: September 07, 2024, 01:24:09 pm »
must be a rebranded intersil 7106 lcd  dmm
