Author Topic: New Hantek DSO2X1X models?  (Read 555266 times)
0 Members and 14 Guests are viewing this topic.
Offline Aldo22
Re: New Hantek DSO2X1X models?
« Reply #1950 on: March 09, 2025, 10:09:25 am »
EDIT: the only reason I posted here was to see which is the 'real' dso2d15 thread...
They are both “real”, but the continuation actually takes place here:
https://www.eevblog.com/forum/testgear/hantek-dso2x1x-models-master-thread/
Offline mailtesterhog
  • Country: in
« Reply #1951 on: March 10, 2025, 11:20:35 am »
I recently bought the Owon SDS210s, on the basis of being the same as the SDS1102, except with greater capture depth and the addition of a signal generator.
I have only used it for a short time, trying to problem solve an ultrasound pest plug that has failed.
It was inexpensive and likely fine for my light occasional use. TBD if the lack of extensive trigger options will restrict it for me.
PS, I have access to a Hantek DSO5102P and Zeeweii 3D12, if needed for additional triggers and portability.
Ah well since I'm just buying my first oscilloscope, I guess I should go with the Hantek. It seems to have a (marginally) better UI and I don't think sample depth matters for me that much. 8M should be fine. I really do not like the extremely limited trigger options on the OWON.
On another note, is there any Linux software to use the probe as a "pc based" probe? (DSO2X1X)
Offline Aldo22
« Reply #1952 on: March 10, 2025, 11:38:24 am »
You mean "oscilloscope", not "probe", right?
Not that I know of, but the DSO2000 has a SCPI interface that can be controlled with Linux (pyvisa).
Please use the new thread for further questions:
  • Country: in
« Reply #1953 on: March 10, 2025, 02:00:57 pm »
Yep!
Thanks, I will move to that thread.
Offline puxe
« Reply #1954 on: March 10, 2025, 02:46:31 pm »
I considered the Hantek; the reason why I chose the Owon was because it was marginally cheaper (below the UK import tax limit), it was similar to the older DSO1102 which has pedigree as a good robust basic unit and the Hantek seemed to be reported as less stable, with frequent FW fixes needed to achieve stability (as far as I could tell at the time of research anyway). I also liked the look of the OWON UI.
« Last Edit: March 10, 2025, 05:27:19 pm by puxe »
Offline iw2evk
« Reply #1955 on: March 21, 2025, 12:59:28 pm »
Hi all,
i've a dso2d15.
it's possible with linux ubutu 24.04 control the machine for make a frequency sweep with the internal generator ?ù
Or directly from control panel ?
Thanks
Roberto iw2evl
Milan
Offline Aldo22
« Reply #1956 on: March 21, 2025, 02:00:56 pm »
The built-in AWG has no real sweep mode.
However, the AWG can be scripted via SCPI (pyvisa).
Offline iw2evk
« Reply #1957 on: March 22, 2025, 02:41:41 pm »
Hi, installed freqresp
i've tried
miciomicio22@Iw2evk:~/Scaricati/freqresp$ python freqresp.py  --help
Traceback (most recent call last):
  File "/home/miciomicio22/Scaricati/freqresp/freqresp.py", line 12, in <module>
    from tinysa_htk import *
  File "/home/miciomicio22/Scaricati/freqresp/tinysa_htk.py", line 14, in <module>
    import feeltech
ModuleNotFoundError: No module named 'feeltech'
whats wrongh ??
Thanks
Offline Aldo22
Offline iw2evk
« Reply #1959 on: April 13, 2025, 01:02:45 pm »
i've tried to scan 4 to 10 mhz shorting the output of sgs and input of scope and seem the frquency reponse it's not flat..
What is the correctt sequence for make a sweep ?
Thanks
 Roberto
Offline Aldo22
« Reply #1960 on: April 13, 2025, 02:47:41 pm »
I don't know why the scope measures 304mV at 8.1MHz and 128mV at 8.4MHz.
That makes no sense to me.
The script is only a support. The requirements must of course be met.
You certainly have to use your brain to make a correct setup.
Try to adjust the script header (but this is certainly not the only problem).
#!/usr/bin/python3
FS = 1000000
FE = 10000000
PTS = 10
VPPCh1=5
VPPCh2=5
VDIVDUTCh = "1V"
VDIVREFCh = "1V"
SLEEPTIME = 1 #Adjust to your needs.
With my device, your case looks like in the attached screenshot.
Offline stasalt
  • Country: am
    • https://www.eevblog.com/forum/register2/
« Reply #1961 on: April 29, 2025, 03:01:32 am »
Following this, the new display arrived, fits exactly like the original and the image quality is just as good.
Leaving the AT070TN94 link for everyone:
https://www.aliexpress.com/item/32918916584.html
(It's the 5mm model)
Hi, what kind of monitor was there before the replacement.I have these stripes.
« Last Edit: April 29, 2025, 03:06:50 am by stasalt »
Online DavidAlfa
« Reply #1962 on: April 29, 2025, 05:01:34 am »
 I don't remember...Who cares?
The new one worked great.
The following users thanked this post: stasalt
Offline stasalt
  • Country: am
« Reply #1963 on: April 29, 2025, 05:56:32 am »
 AT070TN94    you can safely order in  DSO2D15  ?
Online DavidAlfa
« Reply #1964 on: April 29, 2025, 01:36:57 pm »
I linked the exact display I bought, can't be safer than that!
Offline stasalt
  • Country: am
« Reply #1965 on: April 29, 2025, 02:11:18 pm »
Thank you and I ordered.
Online DavidAlfa
« Reply #1966 on: April 29, 2025, 02:30:43 pm »
I also bought this screen protector (153x85mm).
https://www.aliexpress.com/item/1005002416444899.html
The following users thanked this post: morgan_flint
Offline stasalt
  • Country: am
« Reply #1967 on: April 29, 2025, 06:44:51 pm »
I don't like films, only a clean screen, it's easier to buy a spare screen, I remove films on all gadgets.
Online DavidAlfa
« Reply #1968 on: April 30, 2025, 03:44:38 am »
It's a tempered glass, not a film.
It doesn't scratch and gives a perfectly clean picture.
Offline stasalt
  • Country: am
« Reply #1969 on: May 01, 2025, 08:07:46 am »
I ordered it.
