Products => Test Equipment => Topic started by: ashok.das81 on February 03, 2021, 03:46:03 pm
Hi all,
I am making the LC meter V2 designed by VK3BHR Phil RIce.
https://sites.google.com/site/vk3bhr/home/index2-html
I have seen many have done this and it works fine, but in my case it is not measuring inductance properly. For example a 90uH coil shows 52uH, 3.3uH shows 0.3uH. The measurement is completely wrong. Capacitance measurement is looking OK. Calibration was done using a 1% 100pF NP0 capacitor. I checked F1 and F2.
F1=00042879 (little lower than recommended value of 00050000 +- 5%)
F2=00032223 (within 71% of F1)
I have used all new components and L is a 100uH +/-20% toroid. C and Ccal are 1000pF NP0 +/-5%. I am using the PCB designed by VK3BHR. The relay is driven by a BC548B transistor as I cannot find a low current relay and I have checked the RELAY its clicking and contact resistance is less than 1 ohm. I am thinking that the +/-20% tolerance for the 100uH toroid is too high. What else could be wrong ? I will provide any other info that is useful for troubleshooting.
Can anyone help me to find out the problem.
Ashok
You might try building the oscillator section from the AADE LC meter design:
https://pe2bz.philpem.me.uk/Comm01/-%20TestEquip/-%20Tester-NonActiveDevice/Cl-251-IndCap-MeterKit/lc-meter-project.htm
(search down to "The Oscillator")
It uses a LM311 comparator. Then you could verify the frequency of the various LC tanks involved.
Thanks for the reply. Yes I am trying to do this. Then I will measure the frequency wing a separate counter to see how the LC tank oscillating
