Author Topic: detent encoders from rigol DS1045Z skip every second time  (Read 1123 times)
Offline andzTopic starter
  • Country: sk
« on: February 28, 2019, 10:29:44 pm »
I recently bought a new oscilloscope from rigol specifically DS1054Z. Everything is working fine expect detent rotary encoders (for setting scale for vertical and horizontal axes) which skips every second time. I have to do two "clicks" in the same direction to move once. Or if I am "clicking" back and forth nothing happens. Do you have experience with something like that? Thanks for yours answers.
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
Re: detent encoders from rigol DS1045Z skip every second time
« Reply #1 on: February 28, 2019, 10:46:00 pm »
Check out the latest firmware that has been released two days ago. From the release notes it incorporates an encoder fix.
He’s like a trained ape. Without the training.
The following users thanked this post: andz
  • Country: sk
« Reply #2 on: February 28, 2019, 10:56:18 pm »
Thank you for answer, can you link me for that specific update which fixes it. Latest I found was v00.04.04.03.05 from 2018/04/28.
  • Country: sk
« Reply #3 on: February 28, 2019, 11:10:47 pm »
I finally found it here: http://www.rigol.com/Support/SoftDownload/3
Thank you very much again!
Offline JohnPen
« Reply #4 on: March 01, 2019, 05:39:09 pm »
This latest firmware Version 04040402  solves the problem.   Vertical  gain, TB et al all work properly now. :)
