Author Topic: Wall-powered tester (especially continuity)  (Read 298 times)
Offline brandon.arnoldTopic starter
    • Brandon Arnold
« on: November 16, 2024, 07:33:27 pm »
Hi all. This may be an unsual ask but I'll give it a shot. Can anyone think of a continuity tester like this:
- compact
- wall-powered
- no battery, no notification that the battery is running out, no auto-off to conserve battery
I spend a lot of my free time reverse engineering PCBs. My environment is usually the couch. The problem I come up against, is my volt meters have batteries that seem to go out very quickly. The majority of the time they sit there unused, but when I need to do a test, I want it to be ready to go. Usually I have to rotate the dial, press a button, put the leads together to make sure it's working. And on top of that, the meter has a battery timeout; basically it will start beeping telling me to turn it off, and will even turn itself off eventually. This is borderline infuriating to me  :-DD
On the other hand I don't want a giant lab table setup on the end table, here, either.
-Brandon
    • Brandon Arnold
Re: Wall-powered tester (especially continuity)
« Reply #1 on: November 16, 2024, 07:51:33 pm »
Huh. This OWON one on Amazon may do.
Edit: Just bought. Let's see.
I read the manual and it has wall power, can disable auto-off, and does continuity test with a beep.
« Last Edit: November 16, 2024, 08:10:46 pm by brandon.arnold »
