Today from Ebay . . .
With user manual, remote controll manual and 4 roll of paper for the printer.
Not exactly the right thing for some electronic-smd-guys. Maybe someone is interested. I have fun to play around with it
Round about from 1988. Fully functional and precise. And from W&G you can expect a high build quality. Only the printer jammed. Has two outputs (Volts & Amps) on the rear for an oscilloscope.
Direct current measurements up to 30A, voltage up to 500V. Comes with a 1000/1 A current clamp. Measures up to the 50th harmonic.
1st picture: DUT is a vacuum cleaner at full power. ~6.05A at 225V
2nd picture: Harmonics in % of the fundamental (50 Hz). Cursor is at 50 Hz.
3rd picture: DUT at ~40% power
4th picture: Overview of effective, reactive and apparent power
That was only a quick play around. Have to read the friendly manual
