thanks for your reply. I cannot be sure if it has a reverse voltage protection. The case is made of plastics. There is a bnc and its shield is connected to the outer sleeve of the jack. There is another connector marked with an "earth icon" which is not connected to the jack. As you say, normally the bnc ground or the case goes to the negative. I would like someone to confirm this by measuring his own unit, if possible.
