Author Topic: Yokogawa WT1030M Digital Power Meter  (Read 3993 times)
Offline zenerTopic starter
« on: December 19, 2023, 11:58:48 am »
I picked up this 3 phase power meter, which seems to work OK.   I have taken pictures of all the boards and copied the EPROM's.   The manual is available on the Yokogawa website.   I want to try using the GPIB interface.   If anyone in interested in any of the images or photos, let me know.
Re: Yokogawa WT1030M Digital Power Meter
« Reply #1 on: December 19, 2023, 07:06:32 pm »
My goal with this device is to build a single phase to 3 phase converter.   A necessary part of that is to tune the capacitors to balance the generated phase.   That is tricky, and this should help.
Online coppice
« Reply #2 on: December 19, 2023, 07:22:01 pm »
Interesting. I've never seen a Yokogawa power meter with a printer in it before. What sort of things can you print with it?
« Reply #3 on: December 19, 2023, 07:35:06 pm »
I don't know what I can print, and I don't know if the printer even works.   Without the front door, the paper would not even stay in place.   I just picked the unit up, and so I have not done much with it other than my usual collect all the information that I can about it.
Offline aeg
« Reply #4 on: January 08, 2024, 09:10:54 am »
I have this unit's cousin, a WT2010. Here is a sample printout from a few years ago when I was measuring a power supply's no-load consumption. It prints whatever you have selected on each of the displays.
