Author Topic: Was gonna get a ds1000z but......  (Read 9308 times)
Offline edavid
Re: Was gonna get a ds1000z but......
« Reply #25 on: August 17, 2013, 04:54:59 am »
But reading everything ive read a recap and a fresh battery for the calibration data and a heat sink on u800 hybrid is in order.
Maybe backup the cal data if i can.
Yep, imo backing the cal data is the highest priority in the to do list for that beast of yours.
Assuming it uses the same part as 2465B at the A5 digital board, just fyi, Digikey carries quite fresh stock of the pesky battery backed up ram used in that scope. Bought mine few months ago with date code 2012, while my original DS1225Y that came with the scope with date code 1989  :o and amazingly still working fine, although the cal data already backed up and copied to the fresh one.
No.  The 2467 is the same generation as the 2465A.  Then there was a 2467B that was similar to the 2465B.
Offline ahnuts72
« Reply #26 on: August 17, 2013, 11:15:23 pm »
I want to peel back the sticker on the ram module to see the date code but
I'm afraid the face will come off and leave some paper and adhesive on the chip.
I really don't want to go rubbing all over the chip.
Another question
What would be the best way to remove the chip to backup the cal data
I have solder braid not the best but i do have some and one of those spring
loaded vacuum pumps.
Would it be better to buy a de-soldering gun to remove it to lessen the chance
of damaging the chip and losing the cal data?
Offline echen1024
  • 15 yo Future EE
« Reply #27 on: August 17, 2013, 11:49:36 pm »
Another question
You might as well take solder jumper wires on the board, and hook those into an EEPROM programmer, and read the data. Thus, when you take it out, even if you damage it, you'll have a memory dump of everything inside, and can flash it onto your new memory chip.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline ahnuts72
« Reply #28 on: August 18, 2013, 12:02:51 am »
Thanks that thought crossed my mind but i haven't dealt
with programming or reading any type of ic before so wasn't sure
if I could do it in board or not.
Offline ahnuts72
« Reply #29 on: August 24, 2013, 07:45:10 am »
Houston we have a problem!!!!!! :-BROKE
Was trying to probe a ramp generator I'm building and the scope just shut off and wont come back on
I wasnt probing anything at the time was looking at the schematic and went to use it and no display.
Pressed the power switch and nothing not even the fan is coming on.
Checked the fuse outside and both fuses inside all fine.
No smell or smoke nothing visually burnt,bulging or leaking.
It just turned itself off and wont come back on.
Tried probing the power connector to one of the options and no voltage at all.(well several mV but should be like +5,+15,-15)
