I believe U and V is the same thing - potential difference. In some countries in Europe U is potential diference - example: U = I*R, units are still in 'V'
I agree.
U = Voltage,
due to some foreign languages use U instead of V (I believe). Somehow I thought it was German (U), but it seems it was different countries. (I'm probably wrong here, it seems it is more likely that the U is because Physics uses it for Potential Energy (U), Source:
http://whatis.techtarget.com/definition/potential-energy-U).
DEFINITION
potential energy (U)
The potential energy is stored when an elastic is stretched, and converted to kinetic energy when the elastic is released. Other types of potential energy include chemical, which is related to the formation of chemical bonds and electrical, expressed as voltage
The following article explains it in more detail, but I knew about it anyway.
https://en.wikipedia.org/wiki/VoltageVoltage, electric potential difference, electric pressure or electric tension (formally denoted ?V or ?U, but more often simply as V or U
But there are other sources as well, such as:
http://www.thefreedictionary.com/potential+differencepotential difference
n
(General Physics) the difference in electric potential between two points in an electric field; the work that has to be done in transferring unit positive charge from one point to the other, measured in volts. Symbol: U, ?V or ?? Abbreviation: pd Compare electromotive force
Third/Fourth and hopefully last source needed:
http://www.utm.edu/staff/cerkal/potential.htmlElectric Potential Energy (U) and Electric Potential (V): (Notes from C. Erkal’s lectures PHYS 221)
I hope I have included enough sources, but there are more, if wanted.
EDIT: But Rigol, may intend the U to mean something else, such as Umbrella, Unijunction Transistor or Unwell
. It is possible that Rigol use the U to mean something else, but I would suspect it is just an alternative to 'V'.
