Hi all. I tried searching the forums about getting an exact answer for the waveform update rate on newer Owon SDS7102V model. If this question has already been posted here please link it me , I'm really sorry I couldn't find it.
I will be getting my 1st analog(100mhz) and digital(100mhz) scopes but have some doubts before purchase.
My question is : Has the waveform update rate been improved on latest version of SDS7102V at lower memory settings ? (similar to Hantek DSO5102B at 4K) Can any one please post/confirm its fastest waveform update rate?
My uses will be : for studying analog and digital signals , glitch hunting , studying noise & ripple in SMPS.
After going through many threads and videos by marmad I find that Hantek DSO5102B is a good choice for glitch hunting while SDS7102V is good for high fidelity. I am seriously stuck between these 2 DSO's past few days
Which one would you recommend considering the uses that I mentioned above?
Lastly, are analog scopes better at finding glitches as compared to DSOs(like hantek DSO5102B) given both have same bandwidth (100Mhz in my case)?
