Hi guys, HMO owners
I would like to ask you to make some measurements on your scope, I plan to create a "comprehensive" table so that we could compare all existing and future HMO scopes. At this point I would need 16 values only.
The measurement - please setup
input signal: 2.5 V peak to peak, 100 kHz square wave (e.g. the built in pattern gen/square wave is ok in newest HMO scopes)
the scope:
- one channel only
- edge trigger, AC filter
- trigger time set to zero
- please setup the trigger level to get max. waveform/s
- all measurements, special settings off
wfm/s - measure the trigger out freq (e.g. with Brymen 869, everyone has one
samples/s - reported by the scope
These would be the values I am interested in at this point:
TB/Record Mode | Max. WFM. Rate - wfm/s, | samples/s | Max. SA. Rate - wfm/s, | samples/s | Auto - wfm/s, | samples/s |
2ns | 14300 | 1G | 900 | 1G | 14100 | 1G |
100ns | | | | | | |
5us | | | | | | |
200us | | | | | | |
I hope that I did not forget anything and all clear. Later, we could refine the prerequisites of the measurement, but for now, please measure these values. All participation will be appretiated
Thank you!
