Author Topic: WAVETEK 27XT multimeter  (Read 708 times)
Offline McircuitsTopic starter
  • Country: ph
    • techy at day
« on: December 12, 2022, 11:55:37 pm »
Does anyone here has the Wavetek 27XT? Long time ago it was working well until a co office worker uses it and probably put on the wrong probe slot then uses it to test AC voltage. When he returned it, the Capacitance and Inductance went berserk.
Offline bc888
Re: WAVETEK 27XT multimeter
« Reply #1 on: December 13, 2022, 03:46:10 am »
I do not. However, there is a You tube vid of someone who over currented theirs and they show what happened. Assuming you checked the fuse, this one said the fuse was fine and it blew a trace. Easy fix. Worth watching if nothing else so you are watching out for the balls to fall.
The manual appears to have a maintenance and repair section. ( I didn't download it) here: https://www.opweb.de/english/company/Wavetek/27XT
GOOD LUCK! Hope your issue is so easy. Let us know how it goes.
