Author Topic: Weird new ANENG multimeters - "hybrid" design  (Read 3549 times)
Online Fungus
« on: March 13, 2019, 12:46:37 am »
Looks like ANENG is about to release two new multimeters that have both auto and manual ranges on the dial.
There's the V7 which looks like this... it has manual ranging plus a single "Auto" setting that intelligently detects what you're measuring:
...and the V8 which looks like this - a lot of auto ranges in light blue and a selection of manual ranges for Volts/Ohms:
I like that it has separate range selection for diode/continuity/ohms/capacitance without having to turn the dial then press the range button to get where I want to go but it has the same inverse, battery gobbling display as the Q1 so that probably kills it for a lot of people (me included) unless they've sorted out the battery cutoff voltage. Who's going to be brave enough to find out? (and also if the bar graph is fake or not?)
There's a demo video here, it looks like the physical size won't disappoint anybody who's looking for a big meter:
Both of them are available for pre-order on banggood so it seems they aren't released yet. Price is about $35.
This page has more info and plenty of LOLs in the translation. It also has pics of the "safety tubes" (ie. fuses).
Quote: "Aerodynamic design, full gear anti-burn protection. Good stuff, don't fail!"  :popcorn:
« Last Edit: March 13, 2019, 08:26:31 am by Fungus »
Offline coromonadalix
Re: Weird new ANENG multimeters - "hybrid" design
« Reply #1 on: March 13, 2019, 02:57:46 am »
I dont see any problems with the full auto range,  I would say its a good added bonus function
Gossen Metrahit 28 and 29 have this function, i use it very often, works pretty fast.
Online Fungus
« Reply #2 on: March 13, 2019, 08:11:53 am »
ANENG makes a meter which is only automatic, no range selection at all:
It looks like it even has 1.5V/9V battery test in there. I worry about things like speed of continuity tester though.  :popcorn:
(on the new "hybrid" meters there's a manual selection for that range so I don't imagine it's a real problem)
« Last Edit: March 13, 2019, 08:26:17 am by Fungus »
The following users thanked this post: Marco1971
Offline Muttley Snickers
« Reply #3 on: March 13, 2019, 09:02:39 am »
When I select the image for the V7 LCD model the price is $43.15 and the V8 is 51.78, so the difference is $8.63 AUD between the two models. For some users the dual display on the V8 could be handy and worth the eight bucks, certainly looking forward to somebody doing a side by side review on these.
Offline Electro Detective
« Reply #4 on: March 13, 2019, 10:28:04 am »
SOLD! I'll go the V8, good purr factor, safety tubes,
and tow loads better uphill  :-+
I dunno guys, these wheel choc meters look a bit Mastech-y   :-//
FWIW, I have a couple of Mastechs, they get the job done  :clap:
Offline bitseeker
« Reply #5 on: April 06, 2019, 08:21:11 pm »
White on yellow and white on cyan. Stealth lettering.  ;D
I TEA.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #6 on: April 26, 2019, 07:25:02 pm »
Looks like there is a shift on the design on some models, like the aneng M11:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR11.TRC1.A0.H0.Xaneng+m11.TRS0&_nkw=aneng+m11&_sacat=0
Not a roboto style
If one can make knowledge flow than it will go from negative to positve , for real
Offline //Matt//
  • Country: hr
« Reply #7 on: April 26, 2019, 07:58:08 pm »
Wow, no transistor gain tester! Must be good.  ;)
The following users thanked this post: Ysjoelfir
Offline stj
« Reply #8 on: April 26, 2019, 09:16:17 pm »
looks like the 8002 to me - with rounded buttons.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #9 on: April 26, 2019, 09:33:50 pm »
On the function side is similar to 8002. From inside, looks it has some sort of resettable fuse instead of tiny fuses. The display looks different by the pictures. , range switch also different. Size is about the same.
Offline bitseeker
« Reply #10 on: April 27, 2019, 01:13:05 am »
From the photos, it looks like they can't decide if the meter will have temperature measuring capability or two off positions. ;D
I TEA.
Offline stj
« Reply #11 on: April 27, 2019, 10:29:24 am »
if by "self resetting fuse" they mean a polyfuse, those are far too slow for a meter.
not that they wouldnt use them anyway.
Online Fungus
« Reply #12 on: April 27, 2019, 10:54:57 am »
I've got meters with polyfuses in them.  :)
Seems like an excellent idea if you're messing around with batteries and 5V USB powered circuits.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #13 on: April 27, 2019, 11:10:28 am »
Have a uni-t ut120c which has a polyfuse on the current side and according to the manual, it is rated for 600V max. I would not trust this for more than 12V although. don't now if the one used on the aneng M11 has rating on the manual.
Offline Valver
« Reply #14 on: April 27, 2019, 12:07:45 pm »
Just bought a second V8. Currently on sale at Banggood 24% reduction.
Offline Neomys Sapiens
« Reply #15 on: April 27, 2019, 03:32:14 pm »
:-DD Holds true mostly, although my 'desk bitch', a well used Beckmann DM25xL, might take offense.
« Last Edit: April 27, 2019, 08:49:22 pm by Neomys Sapiens »
Offline Jon.C
  • Country: ad
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #17 on: April 27, 2019, 07:25:41 pm »
it reminds almost a old mp3 player that mustool . I wonder if it is some kind of repurposed product :P
Offline bitseeker
« Reply #18 on: April 28, 2019, 02:18:38 am »
I wouldn't be surprised if the enclosure was originally used for an mp3 player. It reminds me of the low-bandwidth handheld scopes that already took advantage of them.
I TEA.
Offline stj
« Reply #19 on: April 28, 2019, 09:13:47 am »
it's too big for an mp4 player,
it reminds me of a satnav used by hikers.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #20 on: April 28, 2019, 11:44:06 am »
Maybe they plan to include one GPS module in the future and a solar panel :P
Offline stj
« Reply #21 on: April 28, 2019, 04:41:02 pm »
solar panel wouldnt be a bad idea actually,
more sensible than the flashlight in some.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #22 on: April 28, 2019, 06:02:27 pm »
Actually there is one pocket meter from hioki 3245-60 with solar pannel
https://www.calright.com/product/hioki-3245-60-solar-hitester-500v-ac-dc/
Offline Jon.C
  • Country: ad
« Reply #23 on: April 28, 2019, 08:02:12 pm »
curious
Main Power Supply   Rechargeable lithium-ion battery powered by solar source: 8 hours of use available on 3 hours of charging at 50,000 lx
Secondary Power Supply   Coin type lithium battery (CR2032) × 1, Continuous use with secondary battery: 150 hours
Offline NANDBlog
« Reply #24 on: April 28, 2019, 08:26:43 pm »
1000V and 60MOhm on this meter?
I cannot wait until they add the 200A range and the 100KV or the femtofarad range to it.
The following users thanked this post: 001
Offline stj
« Reply #25 on: April 29, 2019, 09:06:27 am »
nice, for the northern hemisphere.
i dont know about leaving it in the sun in a hot country though - not with lithiums in it!!  :scared:
Offline Jon.C
  • Country: ad
« Reply #26 on: May 02, 2019, 08:38:14 pm »
well, the display and refresh rate is not bad   :-//
Online Fungus
« Reply #27 on: May 02, 2019, 08:57:52 pm »
But what's the obsession with pretending it's a 'phone?  Am I too old to get the joke? :scared:
Offline Jon.C
  • Country: ad
« Reply #28 on: May 02, 2019, 10:22:33 pm »
I do not understand it either   :-DD
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #29 on: May 02, 2019, 11:38:43 pm »
yet another roboto meter, with colored range switch:
https://ebay.us/A1iRGw
EDIT: About the flat BSIDE meter well almost if it was some kind of surprise , like " it is a phone??? No it's a meter :P "
« Last Edit: May 03, 2019, 09:22:57 am by malagas_on_fire »
Offline windsmurf
« Reply #30 on: May 03, 2019, 06:58:45 am »
She was obviously getting instructions on how to operate the meter over the metered phone.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #31 on: May 04, 2019, 09:50:10 am »
At least one advantage of having this "auto-everything" meter is that it does not beep at every selection of the rotary dial!
Offline 001
  • Country: aq
« Reply #32 on: May 04, 2019, 04:29:45 pm »
Are all of them  dtm0660 clones?
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #33 on: June 20, 2019, 10:33:14 pm »
Now the weird price aneng meters has come:
RM409B True-RMS Digital Multimeter 9999 Counts With Analog Bar Graph NCV AC/DC
https://www.ebay.com/itm/RM409B-True-RMS-Digital-Multimeter-9999-Counts-With-Analog-Bar-Graph-NCV-AC-DC/133082512962?epid=15011417630&hash=item1efc55fe42:g:xNgAAOSweXddAIwS
Another scam?
The following users thanked this post: windsmurf
Offline totalnoob
« Reply #34 on: June 21, 2019, 12:49:59 am »
Another scam?
Read the manual or you will burn it.
Offline windsmurf
« Reply #35 on: June 21, 2019, 12:51:24 am »
Another scam?
Yeah lots sold I see at that price... can scammers really make money through Paypal this way?
If so, EBay's going to be taking a big hit with all these scams so evident now...
Offline rsjsouza
  • Eternally curious
« Reply #36 on: June 21, 2019, 11:16:41 am »
If the price didn't reek of a scam, I would consider buying it. At the regular price of $30, I would never consider it seriously due to its less than stellar design choices.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #37 on: June 22, 2019, 10:33:55 am »
Sorry if i repeared this but check this uni-t with 2 input jack, low functions and inverted display :P
UNI-T UT123 Digital Color Screen High Accuracy Multimeter for Home Industry P2C9
https://ebay.us/j1xLER
Not much functions and the ut 136b might be better value for the money , unless you want to offer for a beginner
« Last Edit: June 22, 2019, 10:35:47 am by malagas_on_fire »
Offline rsjsouza
  • Eternally curious
« Reply #38 on: June 22, 2019, 01:42:26 pm »
This meter looks quite interesting. Uni-T advertises it for home use - hopefully they have a decent input protection.
The fact it does not have current is a massive help to avoid accidents.
The UT136 (non-plus) series is quite good and compact for electronics use. I have a UT136C. Their "plus" variants are radically different and, in my opinion, lose a lot of the high points of the older generation.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #39 on: June 22, 2019, 06:07:36 pm »
The model is so new that gives me forbiden error on the website :P
http://www.uni-trend.com/html/product/General_Meters/Digital_Multimeters/UT123/
So really fresh new meter from uni-t :P
