Author Topic: What are - for you - the 3 biggest disadvantages of your benchtop DMM(s)?  (Read 15325 times)
Offline skullan
Re: What are - for you - the 3 biggest disadvantages of your benchtop DMM(s)?
« Reply #100 on: September 19, 2020, 02:09:05 am »
I can say a reason why I won't have one at home, is purely due to the "Omg, where the hell do I plug THIS in".
Offline bikeNomad
« Reply #101 on: September 19, 2020, 05:44:26 pm »
I have two Fluke 8840A and one Fluke 8842A meters.
These are remarkably accurate, even many years out of calibration (I've compared with in-cal bench meters at work).
Their disadvantages:
  * VFD displays (I'm making an LED replacement display)
  * no AC+DC RMS readings
  * no continuity buzzer (my LED replacement display will provide this)
  * Can't leave the 4-wire ohms test leads in for other uses (SENSE terminals aren't disconnected in non-Ω ranges)
  * auto-ranging sometimes gets confused
  * current measurement isn't that great
  * AC measurement and IEEE-488 comms are optional (though my meters have both)
I end up using my Fluke 287 handheld DMM for a lot of general purpose work but its start-up time and lack of an AC power supply annoy me.
I'm an autodidact who believes in Sturgeon's Law and wants to continue contributing to the creation and improvement of the other 10% of everything.
Offline Wytnucls
« Reply #102 on: September 23, 2020, 07:04:34 am »
I just took apart an old 8842A that apparently was connected to excessive voltage--at least 1500V---with some power to back it up.  The entire front end protection--4 MOVs and 2 fusible resistors--were incinerated.  I removed the burnt parts and subbed in 2 regular 1K resistors (to be repaired properly later, of course) and the meter works properly and is in cal.  No evidence of any external damage, the circuit board is unharmed (but sooty)  and I'm sure nobody died.  I'd say that is 'robust' although I can't quantify that.
Nowhere in CAT documents does it say the the meter should survive.
Again, 61010-2-033 section 14.101 states:  "The component shall not rupture and shall operate as intended during the test."
IMO, operate as intended means just that, the DMM continues to read properly.
One of the tests I have shown several times is from section 101.3.2.   The criteria, "During and after the test, no damage to the equipment shall occur."  IMO, that's not the test equipment being used to test the DMM they are referring to, it's the DMM.
"After the voltage of 4.4.2.101 has been applied to the METER, the METER shall continue to be
able to indicate the presence of HAZARDOUS LIVE voltages up to the maximum RATED voltage.
NOTE The METER is not required to maintain its normal accuracy. A maximum deviation of 10 % is acceptable."
Of course there are many other cases as I have mentioned before.  But again, just to be clear, this is outside of my area and I am providing my interpretation of what the standard states.    I would find it hard to believe for example that the pass fail criteria for an impulse test would be if the combo generator was damaged or not.    Fungus may see it otherwise.
That said, I would imagine that some of the meters I have looked at would pass both the safety and EMC standards with a wide margin but there are far more that wouldn't come close.
You are taking statements out of context.
'The intent of the standard is to ensure the safety of the operator and surrounding area.
Performance / functional requirements are not covered by the standard'. (1)
101.3.2 deals with the fuse protection on the A/mA ranges. Of course no damage should occur, as a conductive path or spark for 1 minute with a 2000V test applied, would cause havoc and affect the safety of the operator.
4.4.2.101 refers to the voltage (1100V AC) applied to voltage measuring terminals in single fault conditions 4.4, (with either MOV or current limiting resistor shorted). The meter must be able to display the presence of a hazardous voltage in a damaged condition (safety consideration).
As for 14.101 (10 high voltage transients), the standard requires that no hazard shall arise due to the operation of overvoltage limiting component.
The component (MOV, sparkgap) shall not rupture and shall operate as intended during the test.
If the component is heated as a result of this test, it shall not heat other materials to their ignition points.
There is no concern for the serviceability of the meter after the test. (It may or may not survive)
(1) Claudia Sirch is the global chief engineer for medical, laboratory, measurement and control equipment and laser products at Intertek. She has over 25 years of experience in the testing and certification business, and is a lead and technical assessor in the IECEE CB Scheme.  She holds a Bachelor of Science in Engineering Physics from Munich University of Applied Sciences.
« Last Edit: September 23, 2020, 01:53:50 pm by Wytnucls »
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #103 on: September 23, 2020, 07:46:53 am »
Keithley 2002
* Shrouded banana jacks. Would prefer low-thermal 5-way binding posts so much...
* Hot
* No electronically controlled front/rear switching
HP/Agilent/Keysight 3458A
* Poor resistance performance compared to competition
Datron 1281
* No NPLC control => poor speed/perf flexibility
* Not really a disadvantage, but complex calibration procedures :)
« Reply #104 on: September 23, 2020, 05:08:50 pm »
Keithley 2002
Depending on your POV this can be an advantage; I recently picked up a Keithley 2000 quite cheap, as it was showing errors 600:1 and 600:2, which turned out to be just the switch needing cleaning (calculated risk I know).
Offline JoeRoy
« Reply #105 on: November 11, 2023, 02:48:47 am »
I have 34470A, 34465A and DMM6500 on my bench. The Keysight wins for AC, but the Keithley wins for fast sampling/charting.
Please, could you do reviews about the 34470A and 34465A?
Thanks.
Offline KungFuJosh
  • TEAS is real.
« Reply #106 on: November 11, 2023, 03:13:44 am »
I have a Siglent SDM3045 upgraded to SDM3055X-E, and an SDM3055. My only problem is that on a rare occasion, I want a 3rd bench DMM so I don't have to grab one of my other DMMs out of a drawer when two meters aren't enough.
Offline tautech
« Reply #107 on: November 11, 2023, 04:16:51 am »
The 16ch Scanner card model will fix that.  :P
Offline HKJ
    • Tests
« Reply #108 on: November 11, 2023, 07:15:39 am »
I have done the 34461A, the other two can be called improved models of that meter:
https://lygte-info.dk/review/DMMKeysight34461A%20UK.html
The following users thanked this post: JoeRoy
Offline KungFuJosh
  • TEAS is real.
« Reply #109 on: November 11, 2023, 07:00:30 pm »
Yeah, along with the 3rd DMM that comes with the scanner card. 🤣
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
« Reply #110 on: November 11, 2023, 07:04:56 pm »
1. Not portable
2. Large power consumption compared to a handheld
3. pricey
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
Offline HKJ
    • Tests
« Reply #111 on: November 11, 2023, 08:10:50 pm »
1. Not portable
3. pricey
1. Many people have a bench where they use their meter.
2. Mains powered, the large power consumption is probably cheaper than batteries.
3. Not really when comparing specifications.
I use both and do see som advantages to bench meters, but they also have a lot of disadvantages. I.e. You need both in many cases.
For the first DMM a handheld would be best, for the second it is about equal (Depending on what you do), for the third your definitely need a bench meter.
