The value of unplugging depends a lot on where you live. If your power feed is entirely buried its probably a waste of time.
We have buried service lines and I thought that too.
A couple of years ago we had lightning hit a large tree in our front yard. It blew a strip of bark off the tree from the top all the way to the base, traveled horizontally for about 10 feet where it scorched the ground, and then dove into the ground where it hit our buried 240V service line.
We lost a bunch of minor appliances, a TV, a DVR, a couple of computers, two Ethernet hubs, some test equipment, and oddly, about a half dozen GFCI outlets. I was able to fix most of the damage, but replacement cost would have been around $6k total. I think we were lucky.
We now have surge protection on all conductors coming into the house. Don't know if it will stop another direct strike, but hopefully its better than nothing. We've had trees get hit two other times on our property. Maybe we're just in a bad place.
I do unplug expensive test gear now.
