Author Topic: Anritsu 69269A signal generator Burnt up A21 board (filter/rectifier board)  (Read 647 times)
Offline ravig
Hello,
Does any one have schematics or know the DC output voltage from the A21 board from a anritsu 69269A signal generator. The A21 board simply takes the AC line voltage /filters it and rectifies it. I am guessing that the DC voltage is simply line rectified. I want to be sure.. I need to spin a PCB to replace this board since I cannot find a replacement board from anritsu, ebay etc....
The part should be the same for the family of generators that are 692XXA types...
Appreciate it!!
Ravi
 ###rapidrf@gmail.com
(remove the three hashes to email .. done to avoid the spambots)
Offline Etech
  • Banned!
Re: Anritsu 69269A signal generator Burnt up A21 board (filter/rectifier board)
« Reply #1 on: September 11, 2019, 04:23:40 am »
I believe the output is +160V and -160V, these go into the switching power supply A19.
