Author Topic: What is a Magnetic Flow Calibrator?  (Read 2662 times)
Offline CigarsnobTopic starter
« on: February 19, 2015, 09:46:23 pm »
Hi Everyone,
I just acquired an old piece of equipment from a co-worker as we are packing up to move to another facility. I have no idea what it is, but the label says: Magnetic Flow Calibrator. Model: 896CAL. Manufacturer: Foxboro
A quick google search didn't show much except for one ebay listing over in Europe and some other links that didn't seem all that helpful. I did find the link below though and from there it states that magnetic flowmeters can be used for slurries among other purposes. Okay.
http://iom.invensys.com/EN/pdfLibrary/Brochure_Foxboro_Municipal%20MagMeter_05-06.pdf
Any info on this would be great. Thanks for the help.
Offline radhaz
Re: What is a Magnetic Flow Calibrator?
« Reply #1 on: February 20, 2015, 12:36:10 am »
It's for calibrating magmeters.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: February 20, 2015, 12:56:23 am »
Looks like it measures flow rate of a conductive liquid by passing through a magnetic field, presumably measuring the electromagnetically generated voltage
Day Job: Mostly LEDs
« Reply #3 on: February 20, 2015, 06:38:15 pm »
Interesting! Thank you both for your guys' feedback.
« Reply #4 on: February 20, 2015, 07:00:57 pm »
Basically it is a generator, the exact opposite of a MHD pump. A flow of conductive liquid through a magnetic field generates a voltage detected by 2 electrodes inserted into the insulated pipe walls. Probably the only flow measuring system that can deal with pebbles in the flow without having a too large error or breaking. Do not use with ferrous slurries unless it has an AC excitation coil that is periodically switched off so it self cleans. If it uses a permanent magnet you will have to clean tramp iron from it at intervals or live with slightly reduced accuracy as the level builds up and clears with flow.
