Products => Test Equipment => Topic started by: 001 on September 01, 2018, 06:03:24 am
Title: What is better multimeter? Mastech M890C vs MY63 vs M830
Post by: 001 on September 01, 2018, 06:03:24 am
What is better? M890C vs MY63 vs M830
(http://www.plusto.com/images/plusto/items/0/8/C75D93D1313F41E9BB72A0CE31F00787.jpg)
(http://msvar.ru/upload/iblock/c0a/my63.jpg)
(https://www.petervis.com/electronics%20guides/Mastech%20M-830B/mastech-m-830b/mastech-m-830b.gif)
Title: Re: What is better multimeter? Mastech M890C vs MY63 vs M830
Post by: Mameniac on September 01, 2018, 06:27:26 pm
maybe I missunderstood the question, but I prefer a multimeter with a fast display and a real fast diode-tester for fast finding connections on a pcb.
The M830 is a cheap, well working multimeter for the "quick and dirty" test procedures, and if its broken, just throw it away.
The others are a bit more expensive, but not really better.
The thing is : what do you need, what do you prefer ?
Just quick reading some low voltages and check some resistors and diodes ?
Post by: HKJ on September 01, 2018, 07:31:54 pm
That is not really something I would rate as good or even decent multimeters. They will all be fairly precise and with lousy safety.
Add a few $ more to the pot and look for meters that at least have a fuse.
Post by: Kleinstein on September 02, 2018, 08:59:16 am
There is a note the 20 A range is unfused. So I would expect the lower current ranges to have a a cheap 20x5 glass-fuse. At only 200 mA this may not be that bad - bad still not good for a CAT III rating much higher than 12 V.
The more expensive ones have extra feature like capacitance and temperature.
Post by: 001 on September 02, 2018, 11:56:26 am
Hi again! Thanx a lot for yours answers!
I NEED in DCV and R tests only ACV in some case
I prefer 830 for its great display and simplisity...
I see what input impedance of dt830 is only 1M and M890 is 10M
And ACV converter in dt830 is only simple diode (no buffers etc)
Is it problem?
Post by: 001 on September 07, 2018, 12:22:22 pm
nobody cares?
