Author Topic: Sencore 39G219 test lead question  (Read 2054 times)
Offline dorkshoeiTopic starter
« on: November 15, 2021, 04:44:32 am »
Can anyone with a Sencore 39G219 test lead tell me what the cable markings are on the positive/red lead cable?  (red arrow in attached picture).
The cable is marked on mine but they have worn to the point where I cannot read them.,
It is some kind of thin coax (shielded - the shield is connected to the shield on the main RG62).
Offline commongrounder
Re: Sencore 39G219 test lead question
« Reply #1 on: November 15, 2021, 01:32:12 pm »
I checked my copy of the 39G219 lead, and there are no markings at all on the coax segment going to the red ez-clip. I would think it’s a bit of the luck of the draw on such a short bit of cable, since the raw stock they pulled off of to make the lead is probably only labeled every six inches or so. The goal is to keep the overall capacity of the cable low enough to be within the auto-cal range of the analyzer (assuming an LC102). For that short section, I think you could get away with a replacement that fits the physical description of the original. It does need to be able to withstand 1000 volts from the leakage test function, though.
« Reply #2 on: November 15, 2021, 02:58:31 pm »
Having a hard time finding coax which has a 0.1" OD.   I already measured it yesterday before posting and drew a blank.
The black lead is just standard test wire,  again,  1000V capable.
« Reply #3 on: November 15, 2021, 04:54:23 pm »
Yeah. That is pretty dinky stuff. Sencore was probably big enough to have Belden, or some other US business, do custom runs of cable in “Sencore Gray”. I assume your cable is suffering fatigue failure.  I’ve shortened my lead set a couple of times in the years I have owned them. Had no trouble with auto-zeroing.
Offline mr.fabe
« Reply #4 on: November 16, 2021, 02:19:48 pm »
Here's what is stamped on my 39G219 cable leads.  I have also built my own test leads with RG62/U and 16GA stranded wire that tested ok with an LC53,LC75, LC101, and LC103.  I think the original cable lead wire Sencore used for the positive lead was a RG-174/U but I'm not 100% sure.
1324532-0
« Last Edit: November 16, 2021, 02:31:39 pm by mr.fabe »
« Reply #5 on: November 16, 2021, 02:52:16 pm »
I think that is a Wirenetics part number.
« Reply #6 on: November 16, 2021, 04:09:11 pm »
What is the number?  I'm not making it out.
RG-174/U is 50 ohm.  Possible I guess.
« Reply #7 on: November 16, 2021, 08:03:16 pm »
I read 5-24340. Could be an “S” instead of a “5”. That’s similar to some Wirenetics part numbers of cable I have laying around here.
« Reply #8 on: November 16, 2021, 08:49:54 pm »
I think it's an E.  E-24340.
https://www.ebay.com/itm/192573733976
But RG59 is a much larger OD.
« Reply #9 on: November 16, 2021, 11:53:59 pm »
Hmmmm. Yeah. That doesn’t make sense. Don’t know what else to try. Sencore, the test equipment company, has been gone too long to be any help. :-//
« Reply #10 on: November 16, 2021, 11:55:12 pm »
Nah, you're good.  Thanks for the help everyone.  Useful.
