Yup, people also got to work in Model-T Fords. Time moves on and better solutions are avaiable. Why not take advantage of that?
Because there are tradeoffs.
When there aren't tradeoffs, then of course you go with what you call the "better solutions".
Look, Dave has an Instek (the GDS-1104B), he has at least a couple of Siglents, he has a Rigol DS-1054Z, he has a couple of Keysights, he has at least one R&S, at least one Tektronix, and probably others. And yet, the Keysight 1000X is his go-to scope. Why, if it's so incredibly inferior to the rest?
You yourself have argued how much better the Instek's UI is compared with the other "B-brand" scopes, in large part (as I recall) due to its responsiveness. I'm arguing that compared with even the Instek, the Keysight's UI is
superior, at the very least in responsiveness, and
that, combined with its size, is why Dave chooses it to perform off-the-cuff measurements and other things that don't exceed its capabilities, and apparently it's
not often that what he needs to do exceeds its capabilities.
You replaced your Keysight because you needed different capabilities. But that's
you. And despite your arguments in favor of the Instek, your go-to scope is now an R&S, again likely because of its capabilities that you need and that the Instek doesn't have. But again, that's
you, and due to
your specific requirements. What you find most usable depends on what you are actually doing. The Keysight shines for many typical oscilloscope uses, and doesn't do so well for a few. Your use cases fall into that latter category. The plain fact is that Keysight wouldn't be selling
nearly as well as it does for the kind of price it commands if it
didn't do most things well enough. Its responsiveness and usability apparently more than make up for the rest. It's not like the 1000X is some kind of specialty scope (it's rather the opposite, actually -- it's rather basic by today's standards), so the fact that it sells as well as it does for its price means
it must be doing something very right. That something is its usability. Nothing else about it stands out.
This is all subject to change. The competition is improving all the time. But as of now, for responsiveness, the Keysight apparently wins over everything else. Combine that with a diminutive size and it's clear why Dave selects it above all of the considerable number of other choices he has at his disposal for his typical uses.
