Hi, was wondering if anyone could help, I have a hp6227b regulated power supply. When I switch it on with with independent and volts selected. With volts turned to the middle which should be 15volts the master side indicator shows maximum output 30volts and will not adjust, the slave fuctions correctly indicating 15 volts. Any ideas what I need to check?
