Products => Test Equipment => Topic started by: ez24 on October 21, 2015, 05:03:18 am
Title: What is the smallest multimeter
Post by: ez24 on October 21, 2015, 05:03:18 am
Looking for a small multimeter to fit inside a case
I am looking at the longest dimension
I came across this one at 5.1 inches long :
Amprobe DM78C
http://www.amazon.com/Amprobe-DM78C-Credit-Card-Multimeter/dp/B0024V97V6 (http://www.amazon.com/Amprobe-DM78C-Credit-Card-Multimeter/dp/B0024V97V6)
This one at 4.6 inch
Victor VC921
http://www.amazon.com/gp/product/B00C3UKEEM/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687622&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0024V97V6&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1QCMGTFEFV4FSABJ41AY (http://www.amazon.com/gp/product/B00C3UKEEM/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687622&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0024V97V6&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1QCMGTFEFV4FSABJ41AY)
Extech DM110 Mini Pocket MultiMeter
4.2 inches
http://www.amazon.com/Extech-DM110-Mini-Pocket-MultiMeter/dp/B0012W2J0Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1445403219&sr=8-1&keywords=Extech+DM110+Mini+Pocket+MultiMeter (http://www.amazon.com/Extech-DM110-Mini-Pocket-MultiMeter/dp/B0012W2J0Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1445403219&sr=8-1&keywords=Extech+DM110+Mini+Pocket+MultiMeter)
NEEWER® Mini Pocket LCD Digital Multimeter Voltage Meter AC DC Tester DT-95B
3.9 inches
http://www.amazon.com/NEEWER%C2%AE-Pocket-Digital-Multimeter-Voltage/dp/B00DBU0YKW/ref=sr_1_9?s=hi&ie=UTF8&qid=1445402749&sr=1-9&keywords=mini+multimeter (http://www.amazon.com/NEEWER%C2%AE-Pocket-Digital-Multimeter-Voltage/dp/B00DBU0YKW/ref=sr_1_9?s=hi&ie=UTF8&qid=1445402749&sr=1-9&keywords=mini+multimeter)
Any smaller ones out there?
Min requirements  measure volts, amps, ohms    I do not care about Cat rating.  The only thing I care about is size, not quality.  Digital only
thanks
thanks
Title: Re: What is the smallest multimeter
Post by: kwass on October 21, 2015, 05:42:34 am
Since you only care about size, consider this analog meter:  http://www.ebay.com/itm/New-Electric-AC-DC-OHM-Voltmeter-Ammeter-Multimeter-Multi-Tester-MF-110A-/271630865527 (http://www.ebay.com/itm/New-Electric-AC-DC-OHM-Voltmeter-Ammeter-Multimeter-Multi-Tester-MF-110A-/271630865527)
It's only 90mm.
Post by: retiredcaps on October 21, 2015, 05:48:09 am
Uni-T UT20B 95 mm
http://uni-trend.com/UT20B.html (http://uni-trend.com/UT20B.html)
95mm = 3.74 inch
Post by: Psi on October 21, 2015, 05:56:43 am
I've always been tempted to design a dmm the size of 3 credit cards stacked on top. So it could fit in your wallet easy. It would have probes that slide inside.
Something like 3 sheets of 0.5mm pcb with the inner one being just a frame.
Components would be smt on inner layers and display would be matrx of reversemount leds.
It would be fun to design something like that.  It could never be mains rated though
Post by: kwass on October 21, 2015, 06:11:36 am
Uni-T UT20B 95 mm
95mm = 3.74 inch
That's the smallest DMM I found too.  It uses an A23, 12V battery, highly unusual in that most of these pocket DMMs use coin or button cells and run at 3V.
Post by: retiredcaps on October 21, 2015, 06:22:59 am
I remember seeing this meter at my local electronics store about 3 years ago.  They wanted $20 CDN MSRP for it.  I laughed!  :-DD
I found two internal pcb pictures.
http://govnoproger.ru/zhelezo/uni-t-ut20b-obzor.html (http://govnoproger.ru/zhelezo/uni-t-ut20b-obzor.html)
Post by: ez24 on October 21, 2015, 06:23:10 am
Uni-T UT20B 95 mm
95mm = 3.74 inch
The 12v battery is a surprise but I am going to hard wire in the meter so this is not a deal breaker.
A 34 page manual on this cheap meter   :-+
http://uni-trend.com/manual2/UT20B%20Eng%20Manual.pdf (http://uni-trend.com/manual2/UT20B%20Eng%20Manual.pdf)
Also this has a square wave output test that I cannot figure out.  Will make a new post on this.
Post by: Martini on October 27, 2020, 04:12:24 pm
If money is no object, I think this wins the contest:
https://shop.pokitmeter.com/products/pokitmeter
I too am wondering how hard it would be to build a really small meter with retractable leads that wouldn't do high voltage nor high current
Post by: DrG on October 27, 2020, 05:57:55 pm
Honorable Mention?
89 x 47 x 129 mm / 3.5 x 1.9 x 5.1 inch
Post by: 5618 on October 30, 2020, 05:40:41 am
Maybe Allosun EM3082... similar to an old Radio Shack one from 30 years ago.
Post by: eKretz on October 30, 2020, 08:41:47 am
I've got a couple of these lying around the house, pretty handy for simple stuff. They do voltage, resistance and diode (voltage drop) testing:
https://www.google.com/amp/s/softsolder.com/2017/06/02/beckman-dm73-circuitmate-back-from-the-dead/amp/ (https://www.google.com/amp/s/softsolder.com/2017/06/02/beckman-dm73-circuitmate-back-from-the-dead/amp/)
I think this is a similar meter but it's of current manufacture. Only capable of 200mA current measurement unless you use a clamp:
https://www.testequipmentdepot.com/extech/multimeters/pen-style-digital-multimeters/pen-type-digital-multimeter-200vac-dc-200aac-dc-non-contact-voltage-detector-381676a.htm?ref=gbase&gclid=CjwKCAjw8-78BRA0EiwAFUw8LMn20-V86OcAqDBszkvngc_yqdJt2iKJ4mvWZO9hQf9zrpJmFyNFcBoCWqAQAvD_BwE (https://www.testequipmentdepot.com/extech/multimeters/pen-style-digital-multimeters/pen-type-digital-multimeter-200vac-dc-200aac-dc-non-contact-voltage-detector-381676a.htm?ref=gbase&gclid=CjwKCAjw8-78BRA0EiwAFUw8LMn20-V86OcAqDBszkvngc_yqdJt2iKJ4mvWZO9hQf9zrpJmFyNFcBoCWqAQAvD_BwE)
