Author Topic: What is you ideal continuity tester?  (Read 7848 times)
Offline ddavideborTopic starter
    • Smartbox AT
« on: July 16, 2013, 10:32:41 pm »
The question is simple.
For me it nees selectable threshold, selectable max voltage, nice buzzer, maiby selectable frequency.
Light segnalation, maiby blinker.
A little led for light the zone
Must fit nice in the hand, and have interchangeable second probe
For you?
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline Dave
  • Country: si
  • I like to measure things.
Re: What is you ideal continuity tester?
« Reply #1 on: July 16, 2013, 10:36:25 pm »
Latching beeper, fast response. My 87V has both.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline notsob
« Reply #2 on: July 16, 2013, 10:41:15 pm »
Have a look at kripton's collection of continuity tester circuits
http://kripton2035.free.fr/continuity-repos.html
Offline MetraCollector
  • Country: cz
« Reply #3 on: July 16, 2013, 10:58:13 pm »
I am satisfied with my Ag 34401A. :D
Time ago I used MY64. ;D
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: July 16, 2013, 11:00:20 pm »
2 wires with 220 volts ac across them. sparks : contact  :-DD
Offline AG6QR
    • AG6QR Blog
« Reply #5 on: July 16, 2013, 11:49:06 pm »
I use a continuity to get a yes/no answer to whether two things are connected, so I don't need adjustable voltage, threshold, etc.
I do like the latching beeper and fast reaction of both of my Flukes, my 179 and 16.  I also like the fact that they use low enough voltage so as not to send semiconductor junctions into conduction, so they don't indicate continuity through diodes and transistors.
I like the V-Check feature of my Fluke 16.  If I accidentally connect it to a voltage source of more than 4.5V (AC or DC), it will switch to voltage measurement mode and display the voltage.  Without causing any damage whatsoever to the meter.
Offline SLJ
    • Steve's Antique Technology
« Reply #6 on: July 17, 2013, 12:08:54 am »
I use a 87V but thought you might enjoy seeing this early one from the 1920s in my collection:
If the red dot moves out of the window you have continuity.
Here are the instructions:  http://www.stevenjohnson.com/pics/testometer-inst.jpg
Offline zaoka
« Reply #7 on: July 17, 2013, 01:14:33 am »
Old analog Triplett meter is my favorite.
Offline Neilm
« Reply #8 on: July 17, 2013, 06:24:28 pm »
Fast response for a buzzer is a must.
I saw a meter many years ago that played a tune (don't remember or care what) but it took about 5 seconds to begin playing. The only use for the meter was that when it was turned "off"  the display stayed active with a clock that was reasonably accurate.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
    • Smartbox AT
« Reply #9 on: July 17, 2013, 06:27:39 pm »
agilent now do a multimeter with a  tune that indicate the resistance
Offline c4757p
  • adieu
« Reply #10 on: July 17, 2013, 06:32:19 pm »
Tune or tone? I think tone. Though I could see a case for (2.3) Ohm on the (10R) Range.
    • Smartbox AT
« Reply #11 on: July 17, 2013, 06:42:23 pm »
yeah yeah tone bad english
Offline c4757p
  • adieu
« Reply #12 on: July 17, 2013, 06:46:20 pm »
If I understand correctly, I think Neilm's tester actually played a tune... :wtf:
Offline Dave
  • Country: si
« Reply #13 on: July 17, 2013, 07:39:03 pm »
Yeah, Agilent U123xA meters can do that. The pitch of the tone depends on the resistance they measure. It's annoying as f*ck, though. I just have it set to a constant pitch.
The power-on tune was also annoying, I disabled it the first day I got that meter. I don't know what the hell Agilent were thinking when they implemented that tune. :wtf:
Aside from that, it's a really good meter. The measurements are spot on and you can disable the auto power-off function. :-+
Offline komet
  • Shenzhen Retroencabulator Mfg. Co.
« Reply #14 on: July 17, 2013, 07:47:11 pm »
I'd like my continuity meter to measure continuity between the points I intended to touch with the probes, rather than the rather old-fashioned standard of the points I actually did touch. GET ON WITH IT FLUKE
Offline ben_r_
  • A Real Nowhere Man
« Reply #15 on: July 17, 2013, 09:13:57 pm »
Any of the ones built into any of my DMMs...
If at first you don't succeed, redefine success!
Offline Phaedrus
« Reply #16 on: July 17, 2013, 09:17:11 pm »
One that goes "beep" when it detects continuity between the leads.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline Tube_Dude
  • Country: pt
« Reply #17 on: July 18, 2013, 09:25:56 am »
For me too... :-+
Jorge
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #18 on: July 18, 2013, 10:23:32 am »
My vote is for my beloved Polar Toneohm 550. It's tone varies in frequency as the resistance changes and is great for tracking down those elusive shorts on a PCB.
Offline KedasProbe
« Reply #19 on: July 18, 2013, 04:10:50 pm »
ideal:
be able to set current and max voltage.
fast obviously, and a tone that gives you info about the voltage value. freq == voltage
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline c4757p
  • adieu
« Reply #20 on: July 18, 2013, 04:16:47 pm »
Oh, that is just beautiful. Hmm..... I am a massive cheapass, so I don't think I'm going to spend money on a continuity tester, but I think you've just added one more weekend project to my long list...
Offline Bloch
« Reply #21 on: July 18, 2013, 04:20:50 pm »
ideal:
Voltage up to 1000V so it can be used as a megger  :)
Current up to 1000A so it can be used to test bus-bar / connection
Last but not least adjustable sound level  :-+
Offline Tooms
« Reply #22 on: July 18, 2013, 05:00:12 pm »
Hi guys
I am in the process of writing a review of the Fluke CNX multimeter and has just tested the continuity tester function on it and compairing it to other meters.
I have tested the shortest time for an good beep and here is the results..
Fluke 179_____________________0.49 ms
Fluke CNX 3000 Multimeter_______0.68 ms
Fluke 789_____________________0.88 ms
Fluke 287_____________________1.17 ms
Fluke T5-1000_________________4.05 ms
Fluke 27_____________________69.05 ms
Fluke 8846A__________________79.06 ms
I dont have a 87V so i can test that time, sorry.
Tooms
« Last Edit: July 18, 2013, 05:03:55 pm by Tooms »
Offline olsenn
« Reply #23 on: July 18, 2013, 05:05:08 pm »
My ideal continuity tester is one where god speaks to my inner conscience telling me "they are one"
    • Smartbox AT
« Reply #24 on: July 18, 2013, 05:10:07 pm »
ideal:
That's a good idea.
