I'm the guy with the Logic 16 up for sale. I'm on the fence about selling it because I really do love it. I have had the Saleae original logic, Saleae Logic 16 (which I'm selling), Intronix LogicPort, and I just added a Saleae Logic Pro 16.
FWIW, I love the Saleae software and UI. I can't say the Intronix is bad, but I prefer the Saleae, it is easier to use. And it is open, I can write a custom protocol analyzer for it if I need to (like the HD44780 LCD interface one I wrote).
I was on the fence about how useful the analog would be in the Pro 16, but after 10 minutes of using it on a project, I am sold. You don't have to get out your scope or clunky scope probes and you can turn on the analog for signals you want to see how they are behaving, and then turn them back off to save bandwidth/memory once you are happy that they are stable.
The Intronix LogicPort advantages are (1) you can set the logic threshold using 0.05V increments from -6V to +6V which is fantastic, (2) it can sample all of its inputs (34 of them!) at full speed (up to 500M), and (3) its software is stable and can run even on slower PC's. Downsides are that it has a short buffer (2K) which means that you must fiddle around with trigger settings to get the data you want, the UI is not as polished, doesn't have as many analyzers, and the software isn't updated as often.
The Saleae advantages are that you don't have to fuss with trigger settings, there is no sample buffer so you can capture as much as want (given your memory) and look through it at your leisure. I can't say enough positive things about the Saleae team, they are always helpful and just all around great guys to deal with. They have a 6 month trial period and a 3 year warranty so you can't go wrong there either.
The Saleae original Logic 16 is USB2 and can capture 100M for 3 channels, 50M for 6 channels, 40M for 7 channels, 32M for 9 channels, 25M for 12 channels, or 16M for all 16 channels.
The Saleae Pro 16 is USB3 (or USB2 but it is 7 times slower on USB2, speeds like the original Logic 16) and can capture 500M for 4 channels, or 100M for all 16 channels. The analog will use considerable bandwidth if enabled and slow down the sample speed for digital as well.
Good luck!
