Author Topic: Isotech IDS-1102b firmware info  (Read 542 times)
Offline Gazmon
« on: March 07, 2019, 07:19:29 pm »
hi all,
is there a firmware upgrade for this scope currently thats worth doing , mine has version  1.22 , will the GW instek firmware work from there website with an Isotech branded scope? (there the same product ive read)
Would there be any serial decoding etc available with any potential hack for this scope?
just seeking clarification, apologies for repeat questions? and thanks
Gazmon
« Last Edit: March 07, 2019, 07:28:21 pm by Gazmon »
Online tv84
  • Country: pt
Re: Isotech IDS-1102b firmware info
« Reply #1 on: March 07, 2019, 07:29:21 pm »
Supposedly it's the same scope: ISO-TECH IDS-1102B <=> INSTEK GDS-1102B
https://www.eevblog.com/forum/testgear/possible-gw-instek-gds-1000b-hack/msg2007089/#msg2007089
Offline Gazmon
« Reply #2 on: March 07, 2019, 07:34:55 pm »
thanks for you reply
Seems like thats a lot of coding chat there , can i just flash the firmware from GW?
Seems to refer to the 2000E model firmware being suitable for the 1000B is this correct in what i say
Is this a USB Flash? , thanks again
Online tv84
  • Country: pt
« Reply #3 on: March 07, 2019, 07:38:15 pm »
No!  No mixing with the 2000E!
The firmware should be the one from 1000B. But I can't guarantee because I've never seen those scopes.
Offline Mortymore
  • Country: pt
« Reply #4 on: March 07, 2019, 09:43:58 pm »
ISO-TECH is just a rebrand of GW-Instek from RS
check here:
https://uk.rs-online.com/web/p/oscilloscopes/1233753/
https://az.rsdelivers.com/product/iso-tech/ids-1102b/iso-tech-ids-series-ids-1102b-digital/8844722
So, you can find what you need for your IDS-1000B at GW-Instek website, in the download area (hacks apart  ::))
https://www.gwinstek.com/en-global/products/detail/GDS-1000B
Offline Gazmon
« Reply #5 on: March 10, 2019, 09:57:48 pm »
I just noticed there is a Function module` app on there website for the 1000b
Anyone knows what this does as there is no information anywhere about its use??
« Last Edit: March 10, 2019, 10:03:27 pm by Gazmon »
Offline Mortymore
  • Country: pt
« Reply #6 on: March 10, 2019, 11:38:41 pm »
I believe that APP is intend to interact with this training/demo board
https://www.gwinstek.com/en-global/products/detail/GDB-03
