Author Topic: JUNTEK's new DC stabilized power supply can be wirelessly remote controlled  (Read 567 times)
Offline JALEN
I saw another power supply on AliExpress. His design style is not the same as other power supplies. The input voltage is DC 10-75V, the output voltage is 0-60V can be adjusted continuously, and the output current 0-24A can also be adjusted. Continuous adjustment, the black power is controlled by the white remote control. I think the advantage of this is that it can save space on the desktop, and it can completely put the power in a place that does not interfere. :popcorn:
The following users thanked this post: renren, Glen
Offline renren
  • Country: cn
How far is its wireless control range, how big is the display screen, is there any product size。
Offline renren
  • Country: cn
Thank you for your reply, i will consider whether to get it.
Online H.O
There's also a 96V/20A version available, search for DPH9620.
Offline Glen
  • Country: cn
Can 24A work for a long time, we are mainly used for LED testing.
Offline not1xor1
Be aware probably most of posts here are disguised ads by the Chinese seller, with multiple accounts and all from China even when pretending they are from Spain.
