Products => Test Equipment => Topic started by: nightfire on December 31, 2022, 09:12:53 pm
Title: What to look for in a differential probe?
Post by: nightfire on December 31, 2022, 09:12:53 pm
As I will work a bit deeper in power supplies in the near future, I want to have a differential probe (or two...) for my scope.
As I am about to begin to dip my toes in the water in this regard, I do not want to spend a fortune (or more money on a probe than on my scope).
From what I have read, the micsig line of differential probes is some sort of secret tip amongst those kind of probes- priced at around 200something Euros, thats a good starting point, when other probes from Hameg used on ebay are sometimes more expensive. And other companies that are available through german reselllers sometimes begin at 500€.
So certainly there is a difference between those probes, but apart from some datasheets, which things do I have to look out for?
Basically I want to do some probing around mains voltages in powersupplies and lighting fixtures. So I have 230VAC here in Europe, which means around 700V peak-to-peak is needed.
The DP10007 seems to be the best value in the range I want to work, sadly being out of stock with most suppliers actually.
http://micsig.com/Differential%20Probe04/ (http://micsig.com/Differential%20Probe04/)
Title: Re: What to look for in a differential probe?
Post by: TheDefpom on December 31, 2022, 09:59:09 pm
There is a new probe from Migsig, I dont know if you have looked at it yet, the DP750.
http://micsig.com/Differential%20Probe01/ (http://micsig.com/Differential%20Probe01/)
Post by: nightfire on January 05, 2023, 10:23:56 pm
Thank you! From the specs it looks like it has better CMRR, but different connection/cabling.
I would be curious if anyone has had the ability to get some real hands-on experience yet?
