Author Topic: What were these 125 Ohm Tektronix attenuators for?  (Read 492 times)
Offline graybeardTopic starter
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« on: March 28, 2023, 05:27:05 am »
I picked up these two 125 Ohm Tektronix attenuators with many other 50 Ohm attenuators at the W6TRW swap meet last Saturday.  They initially appear to have GR874 connectors, but the center contact is not compatible with a standard GR874 connector.  It will "mate" with a standard GR874, but the center contacts do not connect.
The first part is a Tektronix 017-071 2X (6dB) 125Ω attenuator
The second is a Tektronix 017-050 10X (20dB) 125Ω attenuator
Do you have any idea what these were for?
There are pictures of both below.
« Last Edit: March 28, 2023, 05:44:21 am by graybeard »
    • Chris Grossman
Re: What were these 125 Ohm Tektronix attenuators for?
« Reply #1 on: March 28, 2023, 05:31:44 am »
I also picked up this Tektronix 067-0511-00 variable attenuator which has a 100Ω linear potentiometer and standard GR874 connectors.
« Last Edit: March 28, 2023, 05:36:25 am by graybeard »
Online factory
« Reply #2 on: March 28, 2023, 06:03:23 am »
The 125ohm GR attenuator are used for the Tek 519.
https://w140.com/tekwiki/wiki/519
The following users thanked this post: graybeard
    • Chris Grossman
« Last Edit: March 28, 2023, 03:58:04 pm by graybeard »
