Author Topic: RGB Scope Probes ?  (Read 5350 times)
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
Re: RGB Scope Probes ?
« Reply #25 on: December 06, 2017, 08:13:36 am »
I think it's a cool idea! It almost certainly won't be a thing for the "lower end" passive probes, but the higher end stuff already communicates with the scope on some level so it's in the realm of possibility in the long run.
Offline tablatronix
« Reply #26 on: December 09, 2017, 03:00:05 pm »
Your gonna need fairly large fiber, and a lot of light.
I would prototype this using off the shelf toslink cables, preferable with the standard 1/8" phono optical jacks (or the adapters) on them instead of toslink, it would be easy to make the light distribution box for these to plug into.
« Last Edit: December 09, 2017, 03:10:13 pm by tablatronix »
Online Alex Eisenhut
  • Place text here.
« Reply #27 on: December 09, 2017, 04:33:02 pm »
There should also be RGB on the scope itself, and a sensor on the probes. So when you get confused from all the probes, you just pick up a probe and the scope it's connected to can start flashing, either in soothing lava-lamp colors, or harsh 1990's industrial music club strobing.
Offline JohnPen
« Reply #28 on: December 10, 2017, 09:06:35 am »
Perhaps all new designs should include different wavelength LEDs for each test point!  Then use a wide band optical detector, using a suitable lens above the PCB, followed by selectable narrow band frequency resolution to enable the 'scope' to display each test point signal in the appropriate colour.  A simple colour selector switch on the 'scope' or s/w to automate the process for diagnostics to display the relevant signals.
Offline tooki
« Reply #29 on: December 18, 2017, 01:26:31 am »
I thought the primary point of the color rings on scope probes is that a particular probe has to be compensated for a particular input, and that if you use a probe on a different channel of the same scope (never mind on a different scope) you are supposed to compensate it again. So the rings ensure that you always use the same probe on the same channel input.  So unless you’re gonna also include software-controlled probe compensation, and include an EEPROM so that the probe saves its calibration constants for every input it’s used on, this whole exercise is for naught.
