I’ve got the Agilent 0.65mm and 0.5mm wedge clips which work perfectly on their respective pitches. Anything above 0.8mm is also fine as the standard clips fit! I am having difficulty finding a clip on 0.8mm pitch solution. I've got a 44pin PIC to debug!
Can anyone recommend some fine pitch clips or even a TQFP clip on break out solution?
