I vote for "Reasonably priced oscilloscope Current probes" Also differential probes for high voltage. I look at the prices and just say I will not own them.
Ah ha, but with a Isolated channel DSO there's no need for differential probe for other than HV.
The need for current probes are reduced too as simple current shunt measurements and be made without worry of Gnd loops.
Isolated inputs are suitable for single ended signals which have a low common mode impedance to ground. That covers almost all off-line applications but not differential probe applications.
You imply isolated inputs are not differential inputs.
Considering a 1M scope impedance input and the further impedance (10M, 100M, 1000M) with the correct isolated scope probe (well insulated reference lead and clip), where's the problem?
Educate me please.
tautech
How much of electronics today is built in a way to make limited test equipment usable?
Why is the last stage before a high speed ADC a differential stage?
What all changes when you go to fully differential circuits?
Use a simple thought process. Go back to point to point wire even for power. Now change all the wires to have some resistance.
Look at what you have.
Fully Differential Output:
First you should note an output is no longer using one of the power wires to change it's output and the signal is not using one of the power wires for a return path. When power is needed to change the outputs, equal power is needed from each power wire. Your power bypass cap becomes part of a low pass filter and no longer a coupler of noise on one power wire to the other power wire.
Differential input:
Look at the inputs. The load is between the two output signals. If you use two resistors as a load then the center tap is the center of the signal. No this center tap should not be directly connected to center of power. When the differential input becomes more single ended a signal starts appearing here. You really want the average of this point to be the center of power, a high resistance low pass. Here a single ended output with two resistors to power allow slow correction of power center if power is floating.
There is a cost to do Fully Differential and a lot of gains.
At the very low level the difference between P & N types is compensated for with difference between outputs correct while the center of the outputs change with respect to power center.
You need to look at Fully Differential as the difference between outputs and not as two single ended outputs.
The sad thing is Fully Differential existed back in the tube and transistor days.
