Products => Test Equipment => Topic started by: rbola35618 on December 07, 2013, 03:15:29 am
Title: Where is the record function in the Rigol DS1104 scope
Post by: rbola35618 on December 07, 2013, 03:15:29 am
Hi guys,
I am evaluating the new DS1104 scope. I can't seem to fine where the record function is. I looked in the user manual and it says it should be under the Utiltities menu. I can't find it. Am I having a senior moment or do I have an older model. I thought maybe some of you might know.
Thanks in advance.
https://www.youtube.com/watch?v=At3xddUaUdE&feature=em-upload_owner#action=share (https://www.youtube.com/watch?v=At3xddUaUdE&feature=em-upload_owner#action=share)
Title: Re: Where is the record function in the Rigol DS1104 scope
Post by: marmad on December 07, 2013, 05:55:55 am
The Record feature is a purchasable option on the DS1000Z series. I don't know where/when you got the DSO, but it would have originally come with a certain amount of Trial minutes with the options enabled - but they might have been used up by now.
(https://www.eevblog.com/forum/testgear/where-is-the-record-function-in-the-rigol-ds1104-scope/?action=dlattach;attach=70002)
Post by: tautech on December 07, 2013, 08:11:03 am
REALLY.  :wtf:  :--
Standard feature in Siglent's even the Siglent handheld DSO.  :-+
Post by: marmad on December 07, 2013, 02:44:38 pm
REALLY.  :wtf:  :--
 ;D Are 4-channels, intensity-grading, and 30,000 wfrm/s for $585 standard too?
It just depends what your priorities are.
Post by: Dave Turner on December 11, 2013, 11:43:12 pm
Set Horizontal time base to YT. Then Utility - Record - Record.
See chapter ten of the DS1000Z user guide - www.batronix.com/pdf/Rigol/UserGuide/DS1000Z_UserGuide_EN.pdf (http://www.batronix.com/pdf/Rigol/UserGuide/DS1000Z_UserGuide_EN.pdf)
