Author Topic: Putty like terminal that lets you see values in hexadecimal  (Read 1151 times)
Offline Mr.D2
« on: November 26, 2013, 08:15:40 am »
So, in my project i need to test a rather complicated modem, and i'm trying to send commands using a USB-RS232 adapter linked to a TTL logic converter.
I need a program like putty that lets me send specific number in hexadecimal (because the alphabet of the target integrated circuit is different- GSM alphabet) and that lest me set the endianess and also receive the information and display in exadecimal... any pointers?
Best regards,
alm
  • Guest
Re: Putty like terminal that lets you see values in hexadecimal
« Reply #1 on: November 26, 2013, 08:23:57 am »
RealTerm might work.
Offline Mr.D2
« Reply #2 on: November 26, 2013, 09:19:52 am »
It works wonderfully, thank you so much.   :-+
Best regards
Offline enz
« Reply #3 on: November 26, 2013, 10:16:39 am »
HTerm may also be worth a look:
http://www.der-hammer.info/terminal/
