Hi, i want to measure 2 Mosfet gates after an active PFC (around 400V) output . I try to repair a Manson SDP-2405. Active PFC -> Stepdown (Q7 / Q8 ) see attachement.
To measure the gate of the "upper" Mosfet i need a high voltage probe (>400V Vgs highside switch)..
A differential high voltage probe is a bit expensive only for this measurment.
So i want to buy 1 or 2 "High-Voltage Probes" 100:1 (i think less than 1MHz BW required).
Which one is a good, "cheap" one?
It should be save for the expected voltage (don't want to destroy my scope (max. 300V RMS in)).
I found the P2300C or P2301C from Cleqee on ali express (maybe the p4100 ?) or a testec TT-HV150 / TT-HV250 ?
Do you have other probes in mind which can fit my needs?
