Author Topic: Siglent SDG5000 / SHS800 - upgrade hack/unlock (SOLVED)  (Read 17620 times)
Offline maex
Re: Siglent SDG5000 / SHS800 - upgrade hack/unlock (SOLVED)
« Reply #25 on: February 14, 2021, 04:37:10 pm »
I haven't buy a SHS1000. I need a handheld oscilloscope with isoated inputs. The SHS1062 has e nice size and the best price compared to the RTH1002.
Offline realitycomputer
« Reply #26 on: February 14, 2021, 05:50:40 pm »
Here's a weird one!
I picked up a second-hand SHS806 but noticed that I just get a white background, on boot, rather than the snazzy graphic splashscreen others seem to have!
Anyone know the possible reason for that!?
Is it just a graphic file dumped on the built in storage?
Like if I connected it in USB "Printer" mode to the PC (Mass Storage), should I see it there, but someone has deleted it, possibly!?
(I wouldn't have thought so, but who knows!?) :-/O
My therapist believes this to be the main cause of my inferiority complex.........  :o
Offline natman69
« Reply #27 on: February 14, 2021, 07:28:00 pm »
Which firmware release do you have installed in the scope?
I suggest to install official 5.09.01.05 firmware that comes with two files (.ads. and .cfg, follow inside instructions).
Then you go with 5.09.01.07 patched by tv84.
In some Siglent devices boot splash screen is inside .cfg file (but tv84 and other expert users can be more precise than me).
And I suspect that your actual firmware wasn't properly installed.
Regards
The following users thanked this post: realitycomputer
« Reply #28 on: February 15, 2021, 03:03:34 pm »
Hi, thanks for your reply.
I should have stated, it came with 5.09.01.05 and I downloaded and installed 5.09.01.07 from Siglent at:
https://www.siglenteu.com/download/9233/
And I made a comparison at:
https://siglentna.com/download/17221/
This was, in both cases, a zip file containing only 2 pdf instruction files and SHS800_5.09.01.07.ADS file.
No .cfg file.
The pdf instruction files made no mention of a .cfg file, either.
Basically, the instructions were to put the .ADS file onto a USB stick and plug it in....
Go into the menu to "Update Firmware"
Select the .ADS file in the file browser type window.
It displayed a green progress bar.
The installation appeared to work.
It now reports the new firmware in "System Status"
The device had a white splashscreen when I received it.
It still has a white splashscreen after the firmware update.
The device appears to function quite happily in all other regards.
« Reply #29 on: February 15, 2021, 03:12:40 pm »
I'm starting  to think that the previous owner probably updated to 05 without using the procedure for the .cfg part of the update.
I have now updated to firmware 07
This does not come with a .cfg file. (At least from the 2 Siglent sites I downloaded from!)
So, can I downgrade from 07, back to  05, this time using the correct (.cfg) procedure?
Or, can I simply re-apply the 07 update, but using the .cfg file from the 05 firmware download?
I am confused as to why the 07 firmware does not contain a .cfg file!?  :o
Offline tv84Topic starter
  • Country: pt
« Reply #30 on: February 15, 2021, 03:23:31 pm »
You can use the .cfg at any time provided it's the correct .cfg of that model.
BTW, the .cfg has some protection to allow only permitted installation BUT we never know...
« Reply #31 on: February 15, 2021, 03:25:35 pm »
Ok......
I reasoned that:
The latest firmware (07) requires a minimum existing firmware of 05 (For some reason).
The 05 comes with a new .cfg (Probably the reason it must be installed before 07!?)
The 07 does not come with a .cfg
The .cfg file used in the 05 update must stay on the machine when doing the 07 update, as there appears to be no .cfg file included with the 07 firmware, plus the 07 instructions makes no mention of a .cfg file..
So, I simply carried out the .cfg part of the update instructions from the 05 firmware update (although I've already installed 07)
It seemed to work.
It stated "Update Successful"
I rebooted.....
The splash screen is now there during boot !  :)
I finished with the self-cal procedure.
All seems OK.....
« Reply #32 on: February 15, 2021, 03:28:27 pm »
Thanks for your post, tv84
I was posting my last reply at the same time, so I didn't see it first....
Also, thank you to natman69 for your input, too.
Offline TrendX
« Reply #33 on: February 18, 2021, 12:10:14 am »
Dear tv84
Could you please help me with the generator for a SHS810? I've been searching and trying for hours to get this goddamn scope upgraded to 150M. Every license generator I tried gave different keys and none of them worked in EasyScope SCPI.
I must be making a mistake somewhere but I can't find where.
Any help would be appreciated.
Greetings from Germany
« Reply #34 on: February 18, 2021, 12:57:45 am »
Dear tv84
What SCPI command have you been using ?
See here:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-hack/msg3468864/#msg3468864
Avid Rabid Hobbyist
Offline Photoman
    • PrePress Express
« Reply #35 on: February 18, 2021, 07:17:27 pm »
Im in the same boat.  Im not sure what im doing wrong but I cant get any MCBD code to take.
Offline TrendX
« Reply #36 on: February 18, 2021, 11:41:27 pm »
Dear tv84
See here:
Sorry for the late reply.
I tried MCBD *key* with the generated keys. Both in lowercase and uppercase latters.
I used my S/N and the type that the scope gave me over SCPI to generate the keys.
Tried on both original 810 firmware and the modded 804 firmware from tv84. Never got a reply from the scope but after all those tests and restarts my power on timer had increased by 30.
Offline TrendX
« Reply #37 on: February 19, 2021, 12:25:33 pm »
Got it working now. Dont know where the problem was, but trying on another computer with an older version of windows but newest NI-VISA and EasyScope did the trick. :-+
Offline Photoman
    • PrePress Express
« Reply #38 on: February 19, 2021, 03:44:46 pm »
TrendX, Interesting. I will try it on a different computer and see if it works.
Just curious, which code generator did you use?
Offline TrendX
« Reply #39 on: February 19, 2021, 06:13:45 pm »
I used this script and filled in the data i got from my scope over SCPI.
https://repl.it/@wgoeo/siglent-keygen
I copied the generated key directly into EasyScope with uppercase letters. Got no response from the device over SCPI but after a restart it showed SHS815 on the splash screen as well as in the device info.
Offline Photoman
    • PrePress Express
« Reply #40 on: February 19, 2021, 06:21:43 pm »
Thanks so much!  The generator I used wasn’t the correct one.
Quick question, for SCOPEID, I cant get a response from my SHS806.  Did you just put SHS815 in that field?
Thanks!
Offline natman69
« Reply #41 on: February 19, 2021, 07:29:38 pm »
@Photoman
You can use S/N instead of SCOPEID.
SCOPEID command isn't supported on this scope (see list of SCPI supported commands in the first message)
Offline Photoman
    • PrePress Express
« Reply #42 on: February 19, 2021, 08:10:44 pm »
@Photoman
Thanks.  So im definitely doing something wrong.
Here is the section of that code.  For the model, I have left it as is but I also tried one as SHS815.
SCOPEID = 'SHS8000413xxxx'
SN      = 'SHS8000413xxxx'
Model   = 'SDS1000X-E'
Same result on the SHS, still stuck at SHS804.  I used the 150M option that came out of the code.
In the Siglent EasyScopeX software, I pasted MCBD HUIRZXNPXVM4Y2KF
No response but that seems normal.  On re-powering the scope, same SHS804 as before.
Any ideas where im messing this up?  Thanks!
Offline tkhater
« Reply #43 on: June 27, 2021, 01:36:48 pm »
Stuck at SHS804 as well, and unable to get correct MCBD code for 150M option on an SHS806.  |O
Tried:
SCOPEID = 'SHS08DAxxxxxxx'
SN = 'SHS08DAxxxxxxx'
# Tried the following combinations: 'SDS1000X-E', 'SHS800', 'SHS804', 'SHS815'
Entered MCBD 150Mcodegenerated
Restarted
Stuck at SHS804
Any help appreciated...
  • Country: pt
« Reply #44 on: June 27, 2021, 03:35:10 pm »
 ::) See if you can get there by yourself. Use this SCPI command:
MD5_PR?
Offline tkhater
« Reply #45 on: July 07, 2021, 04:13:12 am »
@tv84 Thanks a bunch.  I am up and running at 150Mhz.  :)
Quick question, why on some Siglent equipment, does the upgrade persist with a reflash to stock firmware, but go away with this particular upgrade on the SHS806?
  • Country: pt
« Reply #46 on: July 07, 2021, 07:40:37 am »
The SHS uses an license upgrade feature like all others. BUT, it seems Siglent locked it with a flag that resides on the CPLD.
In order to upgrade it like almost all others one would have to change that CPLD byte. Then you wouldn't need a patched FW.
Offline CrankyBot
« Reply #47 on: October 09, 2021, 04:08:08 am »
To get the right key, change the keygen code model # from "X-E" to "CML".
« Last Edit: October 09, 2021, 04:15:51 am by CrankyBot »
Offline tonyalbus
    • My Channel
« Reply #48 on: October 05, 2025, 10:34:17 am »
This patch still works, amazing.
i bought an old SHS806 with version 3.01.02.01 (HW: 1.31.3.3)
read well and update first to: 5.09.01.05, after upfate also CFG file and selfcal.
- hardware weird enough indeed changes to (HW: 1.31.3.6)
than updated to official 5.09.01.7 again i did a selfcal
- it did not want to connect correctly to the pc at first, is showed up as unknown-device SHS800, then i changed the printer setting from PRINTER/USBDevice to COMPUTER -> PRINTER back to COMPUTER
Than is suddenly changed COMPUTER to USBTMC .. and after connecting again it did show up correct as Meseuring device and showed-up in VISA too.
than the patched version and run the code generator and all done, great wok to everyone.
Just one question, was anyone able to change the color-schema so you can actually read the values?
2671219-02671223-1
« Last Edit: October 05, 2025, 10:45:16 am by tonyalbus »
The following users thanked this post: michaelToDo
Offline michaelToDo
« Reply #49 on: January 16, 2026, 08:27:12 pm »
Well... took a while, but made my 806 into an 815.
Flashed  'hack' firmware, then:
BEFORE:
*IDN SIGLENT,SHS804,SHS08DADxxxxxx,5.09.01.07
>>>*MCBD xxxxxxxxxxx
AFTER:
>>>*IDN?
*IDN SIGLENT,SHS815,SHS08DADxxxxxx,5.09.01.07
I generated the MCBD (code) from the Replit link above, using:
Model:   SDS1000CML,
SN and ScopeID as SN.
Final piece of the puzzle for me was getting the commands sent... but going down the EasyScopeX rabbit hole solved that for me.
Thanks all for your preceding work!
