+1 for the HP 5315A if you can find one in good condition with the option C, but it will probably be easier to just go for a new FA-2 on eBay. The FA-2 is very compact compared to the HP; it's display is not real large but it is readable. I have both and could live with either one but it's nice to have two counters to compare results.
Another option is a HP 5327B (especially if you like Nixie tubes) and if you can live with somewhat less than 1 GHz. There is a HP 5386A on eBay now with a Buy It Now price of $193.99. I have a similar vintage HP power meter with what looks like the same display as the 5386A and I'm not crazy about the display but I think what matters most is how accurate a counter is - which will be hard to know until you test it and to do that you will probably need another counter to compare it to. Welcome to the Time Nuts slippery slope.
I just turned on the the HP 5327B (which is driven by a 10MHz BG7TBL GPSDO reference signal), the HP5315A (which has no input for a GPSDO reference signal), and the FA-2 (which is also driven by the 10MHz BG7TBL GPSDO reference). I fed the inputs to all 3 counters with the output of a Leo Bodnar GPSDO signal which was set for 49.152MHz. The HP 5227B reads 49152000, the HP5315A reads 49152004 (but it seems to need a long time to warm up), and the FA-2 reads 49151999.99715 or thereabouts. It's important not to confuse resolution with accuracy and sometimes more resolution just provides something between uncertainty and confusion - but if we just want to be reasonably accurate we can probably round the FA-2 from 49151999.99whatever to 49152000.
With counters you have to factor in warm-up time, changing ambient temps, gate time, averaging, and maybe some other stuff. If you just want to order up a counter and be close enough for most hobbyist work and not take up much bench space the FA-2 is probably the way to fly.
PS, one other thing that I find useful on the FA-2 is the ability to measure power.
From the published specs:
Introduction of CH1:
- CH1 Frequency: 1Hz-200MHz
- CH1 Input Impedance: 50 OHM/1M OHM
CH1 Input Sensitivity Reference:
- @50 OHM: 25mVrms-2Vrms
- @1MR: 25mVrms-2Vrms
CH1 Frequency Accuracy:
- 0.1s Gate Time: 0.001Hz@10M
- 1s Gate Time: 0.0001Hz@10M
- 10s Gate Time: 0.00001Hz@10M
- CH1 Test Speed: 11 bits/second@10MHz
- CH1 Power Test Range: -50DBM to +20DBM, 1M to 550M@50 OHM
- CH1 Power Test Accuracy: 0.5DB@10MHz
- CH1 Connector Type: BNC
Introduction of CH2:
- CH2 Frequency: 30MHz-6GHz
- CH2 Input Impedance: 50 OHM
CH2 Frequency Accuracy:
- 0.1s Gate Time: 1Hz@1GHz
- 1s Gate Time: 0.01 Hz @1GHz
- 10s Gate Time: 0.001 Hz @1GHz
- CH2 Input Power: -20dBM to +13dBm@0.5 to 5G
- CH2 Connector Type: SMA
PSS, Having said all that, bob91343's $9.42 (plus $3.50 shipping) eBay product looks like a deal. You could probably start with that and if you feel the need to compare it to something else you could buy another one the same product (or buy two at the same time and maybe they will combine shipping), and for #3 you could go for a FA-2
https://en.wikipedia.org/wiki/Segal%27s_lawedit: typos fixed
