I'd go with a FY6800 or 6900 for low budget or a DG811 from Rigol, which is hackable to DG922
70MHz Function Generator, 2 Channel, 250MSa/sec, 16Bit Resolution, 16M Memory
70 MHz function / arbitrary waveform generator
16 Mpts memory depth per channel for arbitrary waveforms
Dual-channel performance is equivalent to two independent signal sources
High frequency stability: ±1 ppm; low phase noise: -105 dBc/Hz
Built-in high-order harmonic generator (at most 8-order harmonics)
Built-in 7 digits/s, 240 MHz bandwidth full featured frequency counter
160 built-in arbitrary waveforms, covering common signals in engineering, medical and automotive electronics, math processing, and more
Sample rate up to 250 MSa/s, vertical resolution 16 bits
Arbitrary waveform sequence editing function available; arbitrary waveforms also can be generated through PC software
Various analog and digital modulation functions: AM, FM, PM, ASK, FSK, PSK, and PWM
