Author Topic: Whick LCR-meter of eBay?  (Read 6078 times)
Offline cs.dkTopic starter
« on: October 02, 2013, 03:45:05 pm »
I need a LCR-meter and took a look en ebay - It must be in the EU, to avoid extra taxes. http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=lcr+meter&LH_PrefLoc=3
Just need it for testing caps, nothing else - Any experience with some of them?
Offline slashguitar
Re: Whick LCR-meter of eBay?
« Reply #1 on: October 02, 2013, 04:39:22 pm »
If you need it for testing caps avoid the  really cheap ones because they don't have ESR.
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #2 on: October 02, 2013, 04:39:46 pm »
You are rather sparse on details. What frequencies do you want to test the caps at. What will be the caps used in? Do you need to test ESR? etc.
A rule of thumb though is that if it is under $50 its pretty much not worth your money.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
« Reply #3 on: October 02, 2013, 04:51:17 pm »
Thanks for your replies.
Well the caps that will be testet is in regular comsumer-electronic, like monitors, amplifiers, etc. The primary reason for buying this thing is because i have two NAD-amplfiers in bridge-mode. One of them are lower on output, and alot more noisy. I think this could be a bad cap or two? Anyway, it is allways good with new tools :)
I really dont know much about caps and frequency. But i can manage to replace dead ones. Just need to confirm that they are bad.
No problem with 50-100 USD. I just don't wanna buy something that does not do the job.
Offline Wytnucls
« Reply #4 on: October 02, 2013, 05:06:37 pm »
Have a look at this review about the UNI-T UT612:
https://www.eevblog.com/forum/testgear/review-and-tear-down-of-uni-t-ut612-lcr-meter/
In your list at 137 GBP.
« Last Edit: October 02, 2013, 06:44:17 pm by Wytnucls »
Offline Wytnucls
« Reply #5 on: October 02, 2013, 05:17:07 pm »
The cheapest one in your list that I would consider is the Tonghui TH2822A at 95.00 GBP. Limited frequency range, but it should be sufficient to test electrolytic caps.
« Last Edit: October 02, 2013, 05:22:09 pm by Wytnucls »
Offline sync
« Reply #6 on: October 02, 2013, 05:34:52 pm »
Are they class AB amps? Then it's unlikely a bad cap.
« Reply #7 on: October 02, 2013, 06:05:26 pm »
Thanks, and nice review. I did a search for LCR-meters, before posting this, but i did not find it.
It's a NAD 317 and a 214 if i remember correct. Some NAD's also have some speaker output relay fail.
Offline sync
« Reply #8 on: October 02, 2013, 08:57:44 pm »
They are class AB amps. No stressed caps in it. So it's unlikely a bad cap.
Offline Hydrawerk
« Reply #9 on: October 02, 2013, 10:38:58 pm »
I am not sure if you can buy this at Ebay, but i am very satisfied with DT-9935. https://www.eevblog.com/forum/testgear/cheap-lcr-meter-cem-dt-9935/
alm
  • Guest
« Reply #10 on: October 03, 2013, 09:45:05 pm »
Tonghui is an excellent brand - many respected western manufacturers rebrand products from Tonghui.
Many respected western manufacturers? Can you list a few? I think BK Precision may rebadge a Tonghui LCR meter, but I'm not sure if I consider them respected. They mostly seem to rebadge mediocre to decent quality Chinese equipment with a huge mark-up these days.
Mike seemed reasonably happy with the Applent LCR meter in his review. Now that they stopped shipping the broken power supply, I think the Mastech MS5308 is a decent choice with good features (eg. real four-wire leads) and an acceptable quality (review 1, review 2).
« Last Edit: October 03, 2013, 09:47:05 pm by alm »
