Author Topic: who has replaced a Rigol oscilloscope fan because of noise?  (Read 7228 times)
Offline djacobowTopic starter
  • takin' it apart since the 70's
« on: August 16, 2014, 03:22:19 am »
My DS2072 is not particularly noisy, but it's the noisest thing in my lab and it kind of bugs me. I've seen lots of people talk about replacing the fan to make their scope quieter, but I don't think I've seen anyone report back.
I suspect a good portion of the noise is the wind through the grill, not the fan itself. If so, replacing the fan won't help much.
Who has done it and what were your results?
Offline WesleyK
Re: who has replaced a Rigol oscilloscope fan because of noise?
« Reply #1 on: August 16, 2014, 08:20:04 am »
I believe the fan itself is quite noisy, so you might want to replace the fan too. The fan rigol is using is a GLOFN GFA06015H12H which produces 36dBa of noise while doing 34m3/h. I might replace mine with a noiseblocker or noctua fan:
Noiseblocker 29m3/h, 17dBa:
http://www.blacknoise.com/site/de/produkte/noiseblocker-it-luefter/nb-blacksilent-pro-series/60x60x25mm.php
Noctua 29.2m3/h, 19.3dBa:
http://www.noctua.at/main.php?show=productview&products_id=48&lng=en&set=1
But both have a slightly lower airflow than the stock fan so I'm not sure yet. They should be much quieter though.
Offline Mark_O
« Reply #2 on: August 16, 2014, 12:47:48 pm »
Wes, it depends on what kind of environment you'll be using them in.  They have to be designed to handle worst-case ambient temps.  For those of us working in air-conditioned offices or homes, and not in tropical heat, I wouldn't worry at all about the 10% lower airflow on the two units you pointed out.
I'll probably pick up one of the NoiseBlocker PR-2's you pointed out, if I pick up a new Rigol.  So thanks for the links.
« Reply #3 on: August 16, 2014, 07:29:11 pm »
Thanks, guys for the feedback. I'm going to try one of these, but not the case mod.
Offline Salas
  • Country: gr
« Reply #4 on: December 09, 2014, 08:52:14 pm »
The DS2072 always seemed somewhat noisy to me too. I recently watched this video:
Could find the specific fan type locally for ~6 Euros. So I did the mod as recommended in the video. PSU end male connector has reverse polarity on the replacement fan, so wire colors need be switched at the splice not to use the old connector for keeping the original fan intact. Air pressure did not seem as strong as original in my free air test. The video footnote says the chips temps were tested adequate though. My subjective noise result is 50% quieter and lower pitch than before. Happy about that and agreeing to the video author. Regarding heat after well warmed up with both channels running, it gives 35C at the side exit for 22C room ambient.
« Last Edit: December 09, 2014, 09:00:19 pm by Salas »
