Author Topic: Why 26.5GHz?  (Read 5122 times)
Offline tkamiyaTopic starter
Why 26.5GHz?
« on: January 10, 2019, 02:14:03 pm »
Some spectrum analyzers as well as frequency counters are rated for 26.5GHz.  Why .5?  It would make much more sense if it was 25 or 30GHz, but 26.5?  Is there a historical or technical reason for this odd choice of bandwidth?
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Why 26.5GHz?
« Reply #1 on: January 10, 2019, 02:41:57 pm »
Strange instrument specifications or "limitation" are sometime caused by laws.
Offline Eric_S
Re: Why 26.5GHz?
« Reply #2 on: January 10, 2019, 02:47:28 pm »
Is it tied to the K-band, perhaps?
https://en.wikipedia.org/wiki/K_band_(IEEE)
The IEEE K band is a portion of the radio spectrum in the microwave range of frequencies from 18 to 27 gigahertz (GHz). The range of frequencies in the center of the K band between 18 and 26.5 GHz is absorbed by water vapor in the atmosphere due to its resonance peak at 22.24 GHz, 1.35 cm. Therefore these frequencies experience high atmospheric attenuation and cannot be used for long distance applications. For this reason the original K band has been split into three bands, Ka band, K-band, and Ku band as detailed below.
Offline tsman
Re: Why 26.5GHz?
« Reply #3 on: January 10, 2019, 02:49:01 pm »
Probably because the lower limit of the Ka band is 26.5GHz. If you want to do something in the Ka band like satellite links then they want you to pay extra for the fancier models.
Offline coppercone2
Re: Why 26.5GHz?
« Reply #4 on: January 10, 2019, 02:56:42 pm »
It might be because of connectors. I think you need to go to K from 3.5mm.
Re: Why 26.5GHz?
« Reply #5 on: January 10, 2019, 03:15:42 pm »
Hum.....  ANY of them could be a reason.  All very convincing!
Online tcottle
Re: Why 26.5GHz?
« Reply #6 on: January 10, 2019, 03:29:24 pm »
The upper limit of WR-42 waveguide is 26.5GHz
Offline DaJMasta
    • medpants.com
Re: Why 26.5GHz?
« Reply #7 on: January 10, 2019, 04:04:03 pm »
This was always my go-to explanation, but there could be any number of potential ones.  Manufacturers will often make special tight-tolerance variants of connectors that can run well beyond a typical connector's spec, letting them connect to cheaper interfaces while letting them advertise the high bandwidth.  I guess it sells more interface connectors too!
Offline coppercone2
Re: Why 26.5GHz?
« Reply #8 on: January 10, 2019, 05:16:56 pm »
yea but then you end up with pain in the ass 'metrology grade' connectors which are not labeled any different then regular connectors and unless someone knows what they are exactly you can destroy them with a lesser connector.
I mean it still happens but if you try to push a SMA to 30 GHz with precision manufacturing processes and someone connects a regular SMA to it, its going to cause many more problems then connecting a lab grade 3.5mm to a metrology grade 3.5mm (which might just cause a small reflection or whatever, rather then completely destroying performance).
I think it keeps the chaos down vs making very very different connectors that look identical. But you do wonder how much more expensive it would be to just make a better standard then SMA..........
But for the sake of argument imagine if someone made like a 40GHz BNC connector with some kind of invisible change. They would probably go to sleep with it at night around their neck in order to protect it from the rest of the workplace. It would be like a riced out honda. No one would ever put premium fuel in that.
« Last Edit: January 10, 2019, 05:20:43 pm by coppercone2 »
Offline Wolfgang
    • Electronic Projects for Fun
Re: Why 26.5GHz?
« Reply #9 on: January 10, 2019, 05:28:22 pm »
What I know this strange number comes from early SMA coaxial cabling and connectors  that ensured a mode free operation up to this frequency (with some safety margin, of course).
Offline coppercone2
Re: Why 26.5GHz?
« Reply #10 on: January 10, 2019, 05:35:29 pm »
when I used the nice knurled 3.5mm and apc-7 the slow connectors started to make me feel sad. The N-connector makes me feel like I am doing something on a car now.
Offline Neomys Sapiens
Re: Why 26.5GHz?
« Reply #11 on: January 11, 2019, 09:58:57 pm »
A car? More of a cart! The N connectors which I want to eliminate at my working place feel like something that ought to be touched with hooves!
Offline Howardlong
Re: Why 26.5GHz?
« Reply #12 on: January 11, 2019, 10:11:34 pm »
I’ve always assumed it’s due to over moding where the coaxial connection system starts to behave like waveguide. Sone info here:
https://community.keysight.com/community/keysight-blogs/rf-test/blog/2016/09/22/can-you-push-sma-cables-connectors-to-millimeter-frequencies
« Last Edit: January 11, 2019, 10:18:39 pm by Howardlong »
Offline jjoonathan
Re: Why 26.5GHz?
« Reply #13 on: January 11, 2019, 10:52:00 pm »
I bet it's the cutoff frequency of the waveguide formed by the cheapest section of pipe available at the nearest hardware store to the MIT rad lab during WWII, or something along those lines.
The following users thanked this post: kony, Eric_S
Offline coppercone2
Re: Why 26.5GHz?
« Reply #14 on: January 11, 2019, 11:29:43 pm »
lol
Offline TheSteve
  • Living the Dream
Re: Why 26.5GHz?
« Reply #15 on: March 03, 2019, 02:14:26 am »
I was testing a pair of ebay special Gore cables today for insertion loss and phase distortion. They were supposed to be 2.1 meter SMA to N cables but are really 2.4 meters and one is 3.5 mm to N. They are right on the money with respect to loss at 18 GHz but thought I'd post this picture which shows the N connectors "moding" at 22.9 GHz. Doesn't really answer the mystical "why 26.5 GHz" value but does show why N is typically only spec'd to 18 GHz.
VE7FM
Offline Wolfgang
Re: Why 26.5GHz?
« Reply #16 on: March 03, 2019, 01:26:02 pm »
Its not odd. Its the moding limit of SMA cables and connectors. Beyond this frequency there are several propagation modes possible, with different attenuations and velocities. If you have the equipment, you can try what happens if you connect a SMA cable (via adapters) to a V or W signal source and you then run more than 26.5GHz thru it. The cable attenuation becomes really irregular.
« Last Edit: March 03, 2019, 04:27:28 pm by Wolfgang »
Offline HalFET
Re: Why 26.5GHz?
« Reply #17 on: March 03, 2019, 02:35:34 pm »
This is honestly more likely than any other option posted so far.  :-DD
Re: Why 26.5GHz?
« Reply #18 on: March 03, 2019, 09:32:38 pm »
I read a while back, this "dip" caused by N connector or it going into "mode" operation is known to Hewlett Packard engineers, yet they decided to offer N connector as standard on most 26.5GHz spectrum analyzers.  Apparently, they absorb discrepancy by wide enough specification for the device.  (In other words, even with this dip, it's within tolerance)  The article also said it always appear at the same place so you just "consider it" as part of interpreting the data.
Offline tefe
  • Country: hk
Re: Why 26.5GHz?
« Reply #19 on: March 04, 2019, 12:50:49 am »
so...why 9k? why 9k as beginning but actually from 0Hz? almost all spectrum analyzers come from here.
second hand eqip : sa, vna, scope, rf gen, dmm.
Offline TheSteve
  • Living the Dream
Re: Why 26.5GHz?
« Reply #20 on: March 04, 2019, 01:52:31 am »
That's easier to answer. Most SA's that start at 9 kHz have a DC block (capacitor) in series with the input. That limits the lowest usable frequency but makes the analyzer front end more robust.
VE7FM
Offline radar_macgyver
Re: Why 26.5GHz?
« Reply #21 on: March 04, 2019, 02:21:04 am »
Keysight's MXA series don't have a DC block (mixer will blow up with DC applied) but still start at 9 kHz. The PXA series go down to 3 Hz if I recall. I thought this was more a limitation of the mixer or perhaps the phase noise from the analyzer's LO.
Offline tefe
  • Country: hk
Re: Why 26.5GHz?
« Reply #22 on: March 06, 2019, 12:43:09 am »
Thanks.
Maybe I mean, why almost all and exactly 9k? Could anyone design a 8k DC block?
Was this limitation set default by HP and followed by?
There are many EMI limitations starting from 9k, but I beleive this is the result.
Offline jjoonathan
Re: Why 26.5GHz?
« Reply #23 on: March 06, 2019, 12:57:52 am »
Sure, but it would inject a bit more charge into the protection diodes on each DC transient, it would require a bit more plate closeness/area (design difficulty), it would probably require spinning a new series of RF baubles (they're typically shared across instruments), and at the end of it all, your fancy expensive microwave analyzer would still have mediocre performance (noise floor, phase noise, etc) compared to a dedicated low-frequency instrument.
Offline TheSteve
  • Living the Dream
Re: Why 26.5GHz?
« Reply #24 on: March 06, 2019, 01:30:33 am »
Most work below 9 kHz but the signal amplitude will drop(unless they don't display below 9). Mine starts at 0 even though it has a DC block and is spec'd to start at 5 kHz.
VE7FM
