How come the price gap between an old crt analyzer on eBay and a new Rigol our Siglent lower end signal analyzer is so narrow?
There are a lot (almost all of the) users here with more experience, knowledge, and insight than me on EE stuff in general and Spectrum Analyzers in particular, but here are a few thoughts.
As background, a while back I found a bit of a deal on a HP8561E. At the time Rigol looked like a good alternative and now Siglent looks good too.
My sense is that a significant tradeoff between a vintage HP and the much newer Rigol/Siglent models is bandwidth. If you don't need the bandwidth of the HP vintage units, I'd think seriously about going with a Rigol or Siglent. Secondarily, I think there is also an advantage (in addition to bandwidth) in favor of the vintage HP's with respect to some performance specs, but I doubt the performance difference will be noticeable for most applications. So, what I think drives the market price proximity is mostly banwidth, followed by some combination of performance and nostalgia. However, in the end (or as the first decision point) either you need a certain amount of bandwidth or you don't. If you can live with the bandwidth and price of the Rigols and Siglents you will get not only decent performance but many more features and much greater (modern software driven) functionality. You will also get a warranty. As for which will last longer, a vintage HP purchased in 2016 or a new Rigol or new Siglent purchased in 2016, I don't know. It might depend on how well the vintage HP was maintained and how lucky we are with any of the models: HP, Rigol, or Siglent.
In my case, I don't use the SA a real lot and I don't do a lot of serious stuff with it, but when I need it or have an idea about something I'd like to checkout (usually wifi related or ham related), it is a very enjoyable tool to use.
Net, net: unless you have a specific stringent performance specification requirement, start by determining your required bandwidth; if the Siglent or Rigol meet the bandwidth requirement and fit your budget, go with the new technology. If you need more bandwidth than you can afford with Siglent or Rigol and you can find a good vintage HP that gives you the needed bandwidth and fits your budget, go with the HP. Either way, a Spectrum Analyzer is a pretty cool piece of test equipment that can help you measure and learn.
PS, in my case I was attracted by 6 GHz bandwidth, pretty low noise specs, and very narrow RBW (1 Hz), plus some nostalgia and general confidence in HP. FWIW, after experiencing the fairly long sweep times that come with very narrow RBW and the additional but only modestly practical information derived from very narrow RBW, I probably put too much emphasis on the RBW. I don't think I will ever use 1 Hz RBW, and to be square most of the time I'm above 1 kHz and often much higher on the RBW. (But if I hadn't seen it for myself, I'd always be thinking "wow, I should have held out for 1 Hz RBW.") For anyone thinking about a SA, if you need narrow RBW and the sweep times are acceptable, go for it, but be careful about over paying for RBW you don't need. Bandwidth on the other hand, is a nice capability and I'm very happy that I held out for 6 GHz (still more bandwidth would have been nicer but for my purposes I don't know what I would have done with it). More FWIW, I get a much bigger kick out of looking at a 40 picosecond rise time on a Tektronix 7904 than I get out of looking at 1 Hz RBW on the HP8561E; go figure... YMMV
