Author Topic: Why aren't these combined into the one piece of test equipment ?  (Read 1806 times)
Offline swmclTopic starter
Please excuse my ignorance but ...
Why isn't the "SIGLENT SVA1032X 3.2GHz 2-port VNA with Spectrum analysis" combined with the "SIGLENT SSA3032X-R Real-time Spectrum Analyzer 9kHz~3.2GHz" ??
Is it just essentially a marketing exercise ?
What can't I do on one machine or the other ?
Is there a technical reason why you would not combine the two machines ?  (This would be backed up by seeing companies buying the two machines I assume.)
Cheers.
Offline tautech
Re: Why aren't these combined into the one piece of test equipment ?
« Reply #1 on: May 14, 2022, 09:23:45 pm »
Cheers.
Apart from BW all these models have identical SA capability: SSA3000X Plus, SVA1000X and SSA3000X-R.
Yes
Offline tv84
  • Country: pt
« Reply #2 on: May 14, 2022, 09:24:08 pm »
Look here.
Basically it shows you that the SVA doesn't have the realtime capability, because it doesn't have the necessary HW.
If you are willing to pay the X-R price, I think Siglent can create a "special" SVA for you.
Look here where I posted the inside of a SSA X-R. For those that have seen SVA/SSAX+ you can see that the HW is different.
Well, maybe SSA3075X+ is a X-R inside...  ::)
The SVA/X+ can't be licensed from 3.2GHz to 7.5GHz. But the X-R can.
« Last Edit: May 14, 2022, 10:29:17 pm by tv84 »
« Reply #3 on: May 14, 2022, 09:48:08 pm »
OK.
So essentially, the market might get to a point where it would demand the two instruments be combined.  Or perhaps we have two legacy product lines that will naturally be combined as technology advances.
I think the VNA has a more sensitive front end or lower noise but I could be wrong.
Thanks for the replies so far.
Offline tv84
  • Country: pt
« Reply #4 on: May 14, 2022, 10:16:46 pm »
Well the combination is already here as the X-R does the whole job. Of course the technology advances will bring the price down.
BTW, a few years ago I was asking myself this same question that you did.
Off-topic curiosity: A Rigol RSA3015N can be "upgraded" to a RSA5032N and costs only 2.500€, while a Siglent SSA3032X Plus which costs 2.900€ can be converted to a SVA but has no realtime capabilities.
Offline tv84
  • Country: pt
« Reply #5 on: May 14, 2022, 10:25:04 pm »
Thinking more on this idea...    ::)  >:D
I wonder if one can convert a SSA3032X-R into a SVA1075X VNA or, at least, a SSA3075X+.
I know that we would loose the realtime capability BUT we would gain the BW increase for several k€ less!  :popcorn:
« Last Edit: May 14, 2022, 10:29:34 pm by tv84 »
Offline tautech
« Reply #6 on: May 14, 2022, 10:30:00 pm »
Consult datasheets.  ;)
Offline tv84
  • Country: pt
« Reply #7 on: May 14, 2022, 10:37:29 pm »
A ballsy & knowledgeable volunteer is needed...
Adding it to the TO DO LIST.  :)
« Last Edit: May 14, 2022, 10:41:48 pm by tv84 »
« Reply #8 on: May 14, 2022, 10:39:17 pm »
Yeah ... not me OK !   :)
The following users thanked this post: tv84
Offline tautech
« Reply #9 on: May 14, 2022, 10:59:23 pm »
There are subtle differences in DANL between model ranges.....suggests different HW.
Offline Martinizhr
  • Country: hr
« Reply #10 on: September 25, 2023, 12:34:22 am »
Hi tv84,
I am considering buying a Rigol RSA3015N. Can you point me to the instructions on how to "upgrade" it?
Thanks in front :)
