Here is how I upgraded my DS2072A in Linux over USB instead of LAN. For some reason I couldn't make my LAN connection work.
Step 1) Connect the back USB port of your scope to your Linux workstation with a USB cable.
Apparently the workstation needs to have a USB2 host controller, not a USB3. EHCI, not XHCI.
See here:
https://www.teuniz.net/DSRemote/Step 2) Test that the connection works.
$echo "*IDN?" > /dev/usbtmc0; cat /dev/usbtmc0
RIGOL TECHNOLOGIES,DS2072A,DS2DXXXXX,00.03.03.SP1
cat: /dev/usbtmc0: Connection timed out
The timed out message is OK. All it means is that cat ran out of data to print out.
Note: You'll need to give yourself permission to open the USB port as it is owned by root when the scope is plugged in.
#chown me /dev/usbtmc0
Step 3) Obtain the binary file from the scope.
$echo ":SYST:UTIL:READ? 1,33554432" > /dev/usbtmc0; cat /dev/usbtmc0 > ds2072a.bin
$ ls -al *.bin
-rw-r--r--. 1 me me 33554444 Aug 23 13:25 ds2072a.bin
Step 4) Download the appropriate version of rigup from
https://gotroot.ca/rigol/. Unzip it. Run it. Version 0.4.2 didn't work for me. Said there were no keys found. 0.4 worked.
$ ./rigup
rigup - Version 0.4
Usage: rigup MODEL DUMPFILE
Creates a set of licenses suitable for the given model.
Needs a memory dump of the DRAM from the specific
device to create the licenses.
MODEL One of DS2072A, DS2102A or DS2202A
DUMPFILE Binary file containing a memory dump
Example:
rigup ds2072a memory_dump.bin
Available expert commands are: (omit parameters for help)
rigup scan [KEYFILE] MEMORYDUMP
rigup serial KEYFILE SERIALNUMBER
rigup license KEYFILE OPTIONS
rigup info KEYFILE LICENSE
rigup search [KEYFILE] MEMORYDUMP
rigup break PUBLICKEY
rigup riglol ...
Step 5) Extract the Keys
$ ./rigup ds2072a ds2072a.bin
rigup ds2072a - Version 0.4
Serial number: XXXXX
NSEH: LGUJTEM-EHNSZZT-ZPF4RUS-TJ9BUSM All options, no bandwidth upgrade
NSER: 4YJDMNS-R9HCABJ-UGYCKC8-H2E3JSM All options, bandwidth 100 MHz
NSEQ: J5RNDTR-E9XQHN2-3JWWN47-KH62USM All options, bandwidth 200 MHz
NS8H: B4GP424-J25BV2T-WMHMS9G-GBGQCVM All options, bandwidth 300 MHz
Step 6) Place the license file on a USB drive.
Create a file <My DS2072A Serial number>.lic with a text editor. NOT A WORD PROCESSOR.
Put one of the keys on the first line in the file. Example: "B4GP424-J25BV2T-WMHMS9G-GBGQCVM" without the quotes. Save the file.
Put the file on the root directory of a FAT 32 USB drive. Mine was 8 GB.
Step 7) Boot the scope. Insert the USB drive in the scope. A popup message should appear asking if you want to upgrade the license on your scope.* The right menu will have an item License in it. Select it and proceed with the upgrade.
* This only happens with firmware 00.03.03.02.06 or later. If your firmware is newer than this, upgrade it.
https://www.rigolna.com/firmware/ Your scope will update the license after the firmware is upgraded.
Enjoy.
